Max messages in Message Queue
Mon Jun 15 16:48:41 UTC 2009
Samuel Bitton wrote:
> I have a local message queue defined with the maximum number of messages
> set to 100 and the max size for each message set to 33 bytes.
> All is fine so far. But when I try to increase the max number of
> messages to 500 I get an RTEMS_TOO_MANY error.
> In the manual I can't find a configuration constant that would limit the
> size of message queues.
> I've tried increasing the task stack size accordingly but no luck.
> Any suggestion as to what my might the source of my problem?
You didn't add memory for the additional messages but
RTEMS_TOO_MANY indicates that there are either too
many queues (returned from create) or too many messages
in the queue -- full (returned from send).
Maybe something didn't get recompiled.
--joel
> Many thanks
> Sam
> This e-mail and any attachments may contain confidential and
> privileged information. If you are not the intended recipient,
> please notify the sender immediately by return e-mail, delete this
> e-mail and destroy any copies. Any dissemination or use of this
> information by a person other than the intended recipient is
> unauthorized and may be illegal.
> rtems-users mailing list
> rtems-users at rtems.org
