Downloading the RTEMS Wiki contents ?
Simon Clubley simon.clubley at googlemail.com
Thu Jun 18 12:35:18 UTC 2009
On 17/06/2009, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Simon Clubley wrote:
> > Does the RTEMS Wiki have anything equivalent to the static dumps
> > available from Wikipedia ?
> > I've looked around the RTEMS Wiki and found the Export page, but it
> > doesn't seem to do what I'm looking for as I can't find a way to
> > export the full Wiki.
>  This would be a Mediawiki question.  I have no idea.
>  Replace RTEMS Wiki with Wikipedia and the answer
>  should be the same.
It appears to be something a Mediawiki site has to choose to setup.
Now I know the RTEMS wiki dumps don't exist, I will follow Jonathan's
suggestion (which is what I've done for other sites in the past). I
had just wanted to make sure you didn't run wiki dumps every so often
before I went down that route.
Simon.
Simon Clubley
