Downloading the RTEMS Wiki contents ?
Thu Jun 18 15:37:08 UTC 2009
Simon Clubley wrote:
>>> Does the RTEMS Wiki have anything equivalent to the static dumps
>>> available from Wikipedia ?
>>> I've looked around the RTEMS Wiki and found the Export page, but it
>>> doesn't seem to do what I'm looking for as I can't find a way to
>>> export the full Wiki.
>>  This would be a Mediawiki question.  I have no idea.
>>  Replace RTEMS Wiki with Wikipedia and the answer
>>  should be the same.
> It appears to be something a Mediawiki site has to choose to setup.
Do you have a link to a howto?
> Now I know the RTEMS wiki dumps don't exist, I will follow Jonathan's
> suggestion (which is what I've done for other sites in the past). I
> had just wanted to make sure you didn't run wiki dumps every so often
> before I went down that route.
> Simon.
