Newbie to RTEMS: ADA support issue
Ángel leadzeppelin at gmail.com
Thu Jun 18 13:25:07 UTC 2009
Hi, Simon.
$ i386-rtems4.10-gcc -v
Using built-in specs.
Target: i386-rtems4.10
Configured with: ../gcc-4.4.0/configure --prefix=/opt/rtems-4.10
--bindir=/opt/rtems-4.10/bin --exec_prefix=/opt/rtems-4.10
--includedir=/opt/rtems-4.10/include --libdir=/opt/rtems-4.10/lib
--libexecdir=/opt/rtems-4.10/libexec --mandir=/opt/rtems-4.10/share/man
--infodir=/opt/rtems-4.10/share/info --datadir=/opt/rtems-4.10/share
--build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=i386-rtems4.10
--disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --verbose --with-newlib
--with-system-zlib --disable-nls --without-included-gettext
--disable-win32-registry --enable-version-specific-runtime-libs
--enable-threads --enable-newlib-io-c99-formats --enable-languages=c,c++
Thread model: rtems
gcc version 4.4.0 (GCC)
The configure params for the configure script  were:
../cvs/configure --target=i386-rtems4.10 --enable-option-checking
--disable-maintainer-mode --disable-multiprocessing --enable-posix
--disable-itron --enable-networking --enable-cxx --disable-tests
--enable-rtems-debug --enable-rtemsbsp="pc386" --disable-multilib
--disable-docs --enable-ada
I disabled the tests and docs options because the make step fails when
enabling them.
Thanks!
2009/6/18 Simon Clubley <simon.clubley at googlemail.com>
> On 17/06/2009, Ángel <leadzeppelin at gmail.com> wrote:
> > I am trying to compile the hello_world_ada sample without sucess:
> > ~/RTEMS/ada-examples/hello_world_ada$ make
> >  i386-rtems4.10-gnatmake -g -v  \
> > -I/opt/rtems-4.10/i386-rtems4.10/pc386/lib/include/adainclude
> >          -O -gnata -gnatE -gnato -g hello -o hello.exe \
> >         -bargs -Mgnat_main \
> >         -largs -B/opt/rtems-4.10/i386-rtems4.10/pc386/lib/
> > -specs=bsp_specs -qrtems -mtune=i386  -Dpc386 -Wl,-Ttext,0x00100000  \
> >          rtems_init.o  \
> > After installation, the /opt/rtems4.10/bin directory, which is in $PATH,
> > contains the following files:
> > rwxr-xr-x 2 root root   31214 2009-05-18 19:01 aclocal
> > -rwxr-xr-x 2 root root   31214 2009-05-18 19:01 aclocal-1.11
> >  -rwxr-xr-x 1 root root   14642 2009-04-07 07:05 autoconf
> > -rwxr-xr-x 1 root root    8506 2009-04-07 07:05 autoheader
> > -rwxr-xr-x 1 root root   31811 2009-04-07 07:05 autom4te
> > -rwxr-xr-x 2 root root  257044 2009-05-18 19:01 automake
> >  -rwxr-xr-x 2 root root  257044 2009-05-18 19:01 automake-1.11
> > -rwxr-xr-x 1 root root   20266 2009-04-07 07:05 autoreconf
> > -rwxr-xr-x 1 root root   17098 2009-04-07 07:05 autoscan
> > -rwxr-xr-x 1 root root   33799 2009-04-07 07:05 autoupdate
> >  -rwxr-xr-x 1 root root   21323 2009-06-17 10:42 cklength
> > -rwxr-xr-x 1 root root   21359 2009-06-17 10:42 eolstrip
> > -rwxr-xr-x 1 root root  549352 2009-05-31 10:53 i386-rtems4.10-addr2line
> > -rwxr-xr-x 2 root root  573752 2009-05-31 10:53 i386-rtems4.10-ar
> >  -rwxr-xr-x 2 root root 1007128 2009-05-31 10:53 i386-rtems4.10-as
> > -rwxr-xr-x 2 root root  197780 2009-05-31 22:14 i386-rtems4.10-c++
> > -rwxr-xr-x 1 root root  549160 2009-05-31 10:53 i386-rtems4.10-c++filt
> > -rwxr-xr-x 1 root root  196788 2009-05-31 22:14 i386-rtems4.10-cpp
> >  -rwxr-xr-x 2 root root  197780 2009-05-31 22:14 i386-rtems4.10-g++
> > -rwxr-xr-x 2 root root  195096 2009-05-31 22:14 i386-rtems4.10-gcc
> > -rwxr-xr-x 2 root root  195096 2009-05-31 22:14 i386-rtems4.10-gcc-4.4.0
> > -rwxr-xr-x 1 root root   16412 2009-05-31 22:13 i386-rtems4.10-gccbug
> >  -rwxr-xr-x 1 root root   27456 2009-05-31 22:14 i386-rtems4.10-gcov
> > -rwxr-xr-x 1 root root 2579296 2009-05-31 11:30 i386-rtems4.10-gdb
> > -rwxr-xr-x 1 root root 2579296 2009-05-31 11:30 i386-rtems4.10-gdbtui
> > -rwxr-xr-x 1 root root  611524 2009-05-31 10:53 i386-rtems4.10-gprof
> >  -rwxr-xr-x 2 root root  836824 2009-05-31 10:53 i386-rtems4.10-ld
> > -rwxr-xr-x 2 root root  558932 2009-05-31 10:53 i386-rtems4.10-nm
> > -rwxr-xr-x 2 root root  706488 2009-05-31 10:53 i386-rtems4.10-objcopy
> > -rwxr-xr-x 2 root root 1034616 2009-05-31 10:53 i386-rtems4.10-objdump
> >  -rwxr-xr-x 2 root root  573756 2009-05-31 10:53 i386-rtems4.10-ranlib
> > -rwxr-xr-x 1 root root  253788 2009-05-31 10:53 i386-rtems4.10-readelf
> > -rwxr-xr-x 1 root root  553444 2009-05-31 10:53 i386-rtems4.10-size
> > -rwxr-xr-x 1 root root  549352 2009-05-31 10:53 i386-rtems4.10-strings
> >  -rwxr-xr-x 2 root root  706484 2009-05-31 10:53 i386-rtems4.10-strip
> > -rwxr-xr-x 1 root root    4060 2009-04-07 07:05 ifnames
> > -rwxr-xr-x 1 root root    3083 2009-06-17 10:42 install-if-change
> > -rwxr-xr-x 1 root root   26117 2009-06-17 10:42 packhex
> >  -rwxr-xr-x 1 root root   19322 2009-06-17 10:42 rtems-bin2c
> > -rwxr-xr-x 1 root root   29155 2009-06-17 10:42 unhex
> > We can see that "i386-rtems4.10-gnatmake" is missing.
> As are the other GNAT related utilities. What does "i386-rtems4.10-gcc -v"
> say ?
> If the prebuilt tools don't support Ada (I've never used them as I've
> always built my own tool kit from source) then you will have to build
> your own toolkit.
> The instructions for doing that are in the RTEMS Wiki, but be aware
> that you will need to find the current patch versions as those in the
> Wiki were out of date when I built a new toolkit for RTEMS 4.9.2.
> Simon.
> Simon Clubley
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20090618/83c2f4bb/attachment-0001.html>
