about header files used in score
Fri Jun 19 14:12:35 UTC 2009
Zhu Zhongjie wrote:
> I am sorry, open() and lseek() are not suitable examples, maybe
> execle() opendir() are more suitable.
If you look closely at opendir() you will see that it is disabled
if it is in newlib now.
#ifndef HAVE_OPENDIR
There was a period of time where some C library methods were
copied into RTEMS because newlib didn't have fine enough
granularity on configuring the things we could support.
The exec*() methods are in RTEMS because we don't support
them and these are just stubs.  But now we do pull a lot of them
from newlib and provide the one or two require "system calls".
There was a recent push to ensure we used every possible routine
in newlib even if it meant having a high level routine end up
doing work and failing because we didn't support the required
underlying system call.
There is a fuzzy line between C library and system calls.  We
consider pthread_xxx part of the OS while in GNU/Linux these
are in the C library.  There is no requirement on where things
reside -- just that the .h files and C methods are proper.
--joel
> Regards.
> Zhongjie
> -----Original Message-----
> *From*: Zhongjie <zhurabbit at gmail.com
> <mailto:Zhongjie%20%3czhurabbit at gmail.com%3e>>
> *To*: Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:Joel%20Sherrill%20%3cjoel.sherrill at oarcorp.com%3e>>
> *Cc*: rtems-users <rtems-users at rtems.org
> <mailto:rtems-users%20%3crtems-users at rtems.org%3e>>
> *Subject*: Re: about header files used in score
> *Date*: Fri, 19 Jun 2009 17:46:50 +0800
> Hi,
> I have done much more study about rtems, I am still confused about the c library.
> It looks like libcsupport has implemented some functions like open() lseek() that
> usually in c library.
> If I use those functions, which function will be linked into
> the final executable program?
> Regards.
> Zhongjie
