about header files used in score
Zhongjie zhurabbit at gmail.com
Sat Jun 20 18:51:44 UTC 2009
Hi,
I noticed that in the file newlib/configure.host in newlib 1.17 we defined
EXIT_PROVIDED, but it looks like
newlib does not use it at all, maybe we could remove it?
Regards
Zhongjie
On Fri, Jun 19, 2009 at 10:12 PM, Joel Sherrill
<joel.sherrill at oarcorp.com>wrote:
> Zhu Zhongjie wrote:
> > I am sorry, open() and lseek() are not suitable examples, maybe
> > execle() opendir() are more suitable.
> If you look closely at opendir() you will see that it is disabled
> if it is in newlib now.
> #ifndef HAVE_OPENDIR
> There was a period of time where some C library methods were
> copied into RTEMS because newlib didn't have fine enough
> granularity on configuring the things we could support.
> The exec*() methods are in RTEMS because we don't support
> them and these are just stubs.  But now we do pull a lot of them
> from newlib and provide the one or two require "system calls".
> There was a recent push to ensure we used every possible routine
> in newlib even if it meant having a high level routine end up
> doing work and failing because we didn't support the required
> underlying system call.
> There is a fuzzy line between C library and system calls.  We
> consider pthread_xxx part of the OS while in GNU/Linux these
> are in the C library.  There is no requirement on where things
> reside -- just that the .h files and C methods are proper.
> --joel
> > Regards.
> > Zhongjie
> > -----Original Message-----
> > *From*: Zhongjie <zhurabbit at gmail.com
> > <mailto:Zhongjie%20%3czhurabbit at gmail.com<Zhongjie%2520%253czhurabbit at gmail.com>
> %3e>>
> > *To*: Joel Sherrill <joel.sherrill at oarcorp.com
> > <mailto:Joel%20Sherrill%20%3cjoel.sherrill at oarcorp.com<Joel%2520Sherrill%2520%253cjoel.sherrill at oarcorp.com>
> %3e>>
> > *Cc*: rtems-users <rtems-users at rtems.org
> > <mailto:rtems-users%20%3crtems-users at rtems.org<rtems-users%2520%253crtems-users at rtems.org>
> %3e>>
> > *Subject*: Re: about header files used in score
> > *Date*: Fri, 19 Jun 2009 17:46:50 +0800
> > Hi,
> > I have done much more study about rtems, I am still confused about the c
> library.
> > It looks like libcsupport has implemented some functions like open()
> lseek() that
> > usually in c library.
> > If I use those functions, which function will be linked into
> > the final executable program?
> > Regards.
> > Zhongjie
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>   Support Available             (256) 722-9985
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20090621/bb76fe9c/attachment-0001.html>
