Debian-host build error...
Ed Sutter esutter at alcatel-lucent.com
Wed Jun 24 20:05:57 UTC 2009
One more snippet of information...
I figured I'd test to see if the problem was blackfin-tools related, so
I installed the powerpc tools and got the exact same error...
els:powerpc-rtems4.10-gcc --help
powerpc-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not fou
nd (required by powerpc-rtems4.10-gcc)
Ed
Ed Sutter wrote:
> Daron & all,
> Yep, that was a typo.  The PATH is correct; however, I hadnt' actually
> tried the cross-compiler out manually, and there is an issue...
> Forget about successful cross-compilation, there are shared libs it
> can't find...
> els:bfin-rtems4.10-gcc --help
> bfin-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not found
> (required by bfin-rtems4.10-gcc)
> A little googling seems to indicate that this is a strange issue with Debian
> because it happens with other tools.  Haven't figured out how to get around it
> though.
> Ed
> Daron Chabot wrote:
>> Hi Ed,
>> Have not used alien to convert rpms to debs, but:
>> Have you verified that your cross-compiler works ? You should get an
>> "a.out" file from cross-compiling this:
>>     int foo(void) { return 0; }
>> Also, I noticed you specified "export PATH=/opt/rtems-4.9/bin:$PATH"...
>> i assume the "rtems-4.9" was simply a typo, and your path actually
>> points to the correct tool versions...
>> -- dc
>> On Wed, Jun 24, 2009 at 12:46 PM, Ed Sutter <esutter at alcatel-lucent.com
>> <mailto:esutter at alcatel-lucent.com>> wrote:
>>     Ian,
>>     Thanks, here's more info...
>>     I'm following the steps from the "Quick Start" wiki page.
>>     First I got the prebuilt tools from:
>>       http://www.rtems.org/ftp/pub/rtems/linux/4.10/fedora/10/i386/
>>     I followed the Debian-specific instructions at:
>>       http://www.rtems.com/wiki/index.php/RTEMS_Prebuilt_Tools
>>     which talk about the "alien" tool and the conversion from .rpm to .deb.
>>     All that appears to work just fine.
>>     Then, referring to the "Example Application Compiling" page
>>     I execute these steps...
>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems
>>      cd rtems
>>      ./bootstrap
>>      cd ..
>>      mkdir bf537Stamp
>>      cd bf537Stamp
>>      ../rtems/configure --target=bfin-rtems4.10
>>     --enable-rtemsbsp=bf537Stamp \
>>        --enable-tests=samples --disable-posix --disable-itron
>>      make all
>>     The error occurs in the "make all" step.  It apparently runs yet another
>>     configure down below, and that's the point where it chokes.  Attached
>>     is the output of the "make all", as well as the config.log file that the
>>     error in the make output is referring to.
>>     Thanks for any help you can offer!  I'm bracing myself for being told
>>     I'm doing something really stupid.  :-(
>>     Ed
>>     Ian Caddy wrote:
>>         Hi Ed,
>>         I am not really sure, but do you have any more details?
>>         Such as when the error occurred, I assume during configure?
>>         If so, did you look at the config.log output to see if it gave
>>         any clues as to why it failed the check for being able to build
>>         executables?
>>         regards,
>>         Ian Caddy
>>         Ed Sutter wrote:
>>             Folks,
>>             Didn't get any responses on this, so I figured I'd try again...
>>             When I reported this error, I was using pre-built tools from:
>>                http://www.rtems.org/ftp/pub/rtems/linux/4.9/redhat/el5/i386/
>>             then the other day I started over using:
>>             The exact same error occurred, so I'm still clueless.
>>             Even the "remotest" of suggestions at this point would not
>>             be in vain
>>             (yea, I'm begging) :-( otherwise, I suppose I have to hunt
>>             down a different
>>             Linux box (non-debian) to isolate this problem.
>>             Thanks,
>>             Ed
>>             Ed Sutter wrote:
>>                 Folks,
>>                 I'm walking through the quick-start procedure for
>>                 building the
>>                 BF537Stamp BSP.  My development host is Debian, and I've
>>                 gotten
>>                 to the point (on the quick-start page) where it mentions
>>                 the error:
>>                 * If you experience a "C compiler cannot create
>>                 executables" error,
>>                 * try fixing your compiler by getting libc-dev
>>                 I ran apt-get install libc-dev and got the following
>>                 message:
>>                 * root:apt-get install libc-dev
>>                 * Reading package lists... Done
>>                 * Building dependency tree... Done
>>                 * Note, selecting libc6-dev instead of libc-dev
>>                 * libc6-dev is already the newest version.
>>                 * 0 upgraded, 0 newly installed, 0 to remove and 1 not
>>                 upgraded.
>>                 Anyone working with a Debian host that has had (and
>>                 overcame) this
>>                 problem?
>>                 Thanks
>>                 Ed
>>                 _______________________________________________
>>                 rtems-users mailing list
>>                 rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>                 http://www.rtems.org/mailman/listinfo/rtems-users
>>             No virus found in this incoming message.
>>             Checked by AVG - www.avg.com <http://www.avg.com> Version:
>>             8.5.375 / Virus Database: 270.12.90/2198 - Release Date:
>>             06/23/09 17:54:00
>>     This file contains any messages produced by compilers while
>>     running configure, to aid debugging if configure makes a mistake.
>>     It was created by rtems-c configure 4.9.99.0, which was
>>     generated by GNU Autoconf 2.63.  Invocation command line was
>>      $ ../../../rtems/c/configure --prefix=/opt/rtems-4.10
>>     --host=bfin-rtems4.10 --build=i686-pc-linux-gnu
>>     --target=bfin-rtems4.10 --enable-rtemsbsp=bf537Stamp
>>     --with-target-subdir=bfin-rtems4.10
>>     --exec-prefix=/opt/rtems-4.10/bfin-rtems4.10
>>     --includedir=/opt/rtems-4.10/bfin-rtems4.10/include
>>     --cache-file=/dev/null --srcdir=../../../rtems/c
>>     ## Platform. ##
>>     hostname = xpcelslinux1
>>     uname -m = i686
>>     uname -r = 2.6.18-6-486
>>     uname -s = Linux
>>     uname -v = #1 Mon May 4 23:59:22 UTC 2009
>>     /usr/bin/uname -p = unknown
>>     /bin/uname -X     = unknown
>>     /bin/arch              = i686
>>     /usr/bin/arch -k       = unknown
>>     /usr/convex/getsysinfo = unknown
>>     /usr/bin/hostinfo      = unknown
>>     /bin/machine           = unknown
>>     /usr/bin/oslevel       = unknown
>>     /bin/universe          = unknown
>>     PATH: /home/els/bin
>>     PATH: /usr/local/bin
>>     PATH: /usr/bin
>>     PATH: /bin
>>     PATH: /usr/games
>>     PATH: /home/els/bin
>>     PATH: /sbin
>>     PATH: /opt/uClinux/bfin-elf/bin
>>     PATH: /opt/uClinux/bfin-uclinux/bin
>>     PATH: /opt/uClinux/bfin-linux-uclibc/bin
>>     PATH: /opt/arm-2007q3/bin
>>     PATH: /opt/rtems-4.10/bin
>>     ## Core tests. ##
>>     configure:1821: checking for gmake
>>     configure:1851: result: no
>>     configure:1821: checking for make
>>     configure:1837: found /usr/bin/make
>>     configure:1848: result: make
>>     configure:1873: checking for RTEMS Version
>>     configure:1875: result: 4.9.99.0
>>     configure:1885: checking build system type
>>     configure:1903: result: i686-pc-linux-gnu
>>     configure:1925: checking host system type
>>     configure:1940: result: bfin-unknown-rtems4.10
>>     configure:1963: checking target system type
>>     configure:1978: result: bfin-unknown-rtems4.10
>>     configure:2006: checking rtems target cpu
>>     configure:2029: result: bfin
>>     configure:2049: checking for a BSD-compatible install
>>     configure:2117: result: /usr/bin/install -c
>>     configure:2128: checking whether build environment is sane
>>     configure:2171: result: yes
>>     configure:2196: checking for a thread-safe mkdir -p
>>     configure:2235: result: /bin/mkdir -p
>>     configure:2248: checking for gawk
>>     configure:2278: result: no
>>     configure:2248: checking for mawk
>>     configure:2264: found /usr/bin/mawk
>>     configure:2275: result: mawk
>>     configure:2286: checking whether make sets $(MAKE)
>>     configure:2308: result: yes
>>     configure:2379: checking for bfin-rtems4.10-strip
>>     configure:2395: found /opt/rtems-4.10/bin/bfin-rtems4.10-strip
>>     configure:2406: result: bfin-rtems4.10-strip
>>     configure:2483: checking whether to enable maintainer-specific
>>     portions of Makefiles
>>     configure:2492: result: no
>>     configure:2593: checking for bf537Stamp.cfg
>>     configure:2607: result: ../../../rtems/c/../make/custom/bf537Stamp.cfg
>>     configure:2899: creating ./config.status
>>     ## Running config.status. ##
>>     This file was extended by rtems-c config.status 4.9.99.0, which was
>>      CONFIG_FILES    =
>>      CONFIG_HEADERS  =
>>      CONFIG_LINKS    =
>>      CONFIG_COMMANDS =
>>      $ ./config.status
>>     on xpcelslinux1
>>     config.status:690: creating Makefile
>>     ## Cache variables. ##
>>     ac_cv_build=i686-pc-linux-gnu
>>     ac_cv_env_build_alias_set=set
>>     ac_cv_env_build_alias_value=i686-pc-linux-gnu
>>     ac_cv_env_host_alias_set=set
>>     ac_cv_env_host_alias_value=bfin-rtems4.10
>>     ac_cv_env_target_alias_set=set
>>     ac_cv_env_target_alias_value=bfin-rtems4.10
>>     ac_cv_host=bfin-unknown-rtems4.10
>>     ac_cv_path_install='/usr/bin/install -c'
>>     ac_cv_path_mkdir=/bin/mkdir
>>     ac_cv_prog_AWK=mawk
>>     ac_cv_prog_MAKE=make
>>     ac_cv_prog_STRIP=bfin-rtems4.10-strip
>>     ac_cv_prog_make_make_set=yes
>>     ac_cv_target=bfin-unknown-rtems4.10
>>     ## Output variables. ##
>>     ACLOCAL='${SHELL} /home/els/rtems/rtems/missing --run aclocal-1.10'
>>     AMTAR='${SHELL} /home/els/rtems/rtems/missing --run tar'
>>     AUTOCONF='${SHELL} /home/els/rtems/rtems/missing --run autoconf'
>>     AUTOHEADER='${SHELL} /home/els/rtems/rtems/missing --run autoheader'
>>     AUTOMAKE='${SHELL} /home/els/rtems/rtems/missing --run automake-1.10'
>>     AWK='mawk'
>>     CYGPATH_W='echo'
>>     DEFS='-DPACKAGE_NAME=\"rtems-c\" -DPACKAGE_TARNAME=\"rtems-c\"
>>     -DPACKAGE_VERSION=\"4.9.99.0\" -DPACKAGE_STRING=\"rtems-c\
>>     4.9.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\"'
>>     ECHO_C=''
>>     ECHO_N='-n'
>>     ECHO_T=''
>>     INSTALL_DATA='${INSTALL} -m 644'
>>     INSTALL_PROGRAM='${INSTALL}'
>>     INSTALL_SCRIPT='${INSTALL}'
>>     INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
>>     LIBOBJS=''
>>     LIBS=''
>>     LTLIBOBJS=''
>>     MAINT='#'
>>     MAINTAINER_MODE_FALSE=''
>>     MAINTAINER_MODE_TRUE='#'
>>     MAKE='make'
>>     MAKEINFO='${SHELL} /home/els/rtems/rtems/missing --run makeinfo'
>>     MKDIR_P='/bin/mkdir -p'
>>     PACKAGE='rtems-c'
>>     PACKAGE_BUGREPORT='http://www.rtems.org/bugzilla'
>>     PACKAGE_NAME='rtems-c'
>>     PACKAGE_STRING='rtems-c 4.9.99.0'
>>     PACKAGE_TARNAME='rtems-c'
>>     PACKAGE_VERSION='4.9.99.0'
>>     PATH_SEPARATOR=':'
>>     PROJECT_ROOT='../$(top_builddir)'
>>     PROJECT_TOPdir='../../$(top_builddir)'
>>     RTEMS_BSP_LIST=' bf537Stamp'
>>     RTEMS_CPU='bfin'
>>     RTEMS_TOPdir='..'
>>     SET_MAKE=''
>>     SHELL='/bin/sh'
>>     STRIP='bfin-rtems4.10-strip'
>>     VERSION='4.9.99.0'
>>     am__isrc=' -I$(srcdir)'
>>     am__leading_dot='.'
>>     am__tar='${AMTAR} chof - "$$tardir"'
>>     am__untar='${AMTAR} xf -'
>>     bindir='${exec_prefix}/bin'
>>     build='i686-pc-linux-gnu'
>>     build_alias='i686-pc-linux-gnu'
>>     build_cpu='i686'
>>     build_os='linux-gnu'
>>     build_vendor='pc'
>>     datadir='${datarootdir}'
>>     datarootdir='${prefix}/share'
>>     docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>>     dvidir='${docdir}'
>>     exec_prefix='/opt/rtems-4.10/bfin-rtems4.10'
>>     host='bfin-unknown-rtems4.10'
>>     host_alias='bfin-rtems4.10'
>>     host_cpu='bfin'
>>     host_os='rtems4.10'
>>     host_vendor='unknown'
>>     htmldir='${docdir}'
>>     includedir='/opt/rtems-4.10/bfin-rtems4.10/include'
>>     infodir='${datarootdir}/info'
>>     install_sh='$(SHELL) /home/els/rtems/rtems/install-sh'
>>     libdir='${exec_prefix}/lib'
>>     libexecdir='${exec_prefix}/libexec'
>>     localedir='${datarootdir}/locale'
>>     localstatedir='${prefix}/var'
>>     mandir='${datarootdir}/man'
>>     mkdir_p='/bin/mkdir -p'
>>     oldincludedir='/usr/include'
>>     pdfdir='${docdir}'
>>     prefix='/opt/rtems-4.10'
>>     program_transform_name='s&^&bfin-rtems4.10-&'
>>     psdir='${docdir}'
>>     rtems_bsp_configure='../../../../rtems/c/src/configure
>>      '\''--prefix=/opt/rtems-4.10'\'' '\''--host=bfin-rtems4.10'\''
>>     '\''--build=i686-pc-linux-gnu'\'' '\''--target=bfin-rtems4.10'\''
>>     '\''--enable-tests=samples'\'' '\''--disable-posix'\''
>>     '\''--disable-itron'\'' '\''--with-target-subdir=bfin-rtems4.10'\''
>>     '\''--exec-prefix=/opt/rtems-4.10/bfin-rtems4.10'\''
>>     '\''--includedir=/opt/rtems-4.10/bfin-rtems4.10/include'\''
>>     '\''build_alias=i686-pc-linux-gnu'\''
>>     '\''host_alias=bfin-rtems4.10'\''
>>     '\''target_alias=bfin-rtems4.10'\''
>>     '\''--with-project-root=../../'\'' '\''--with-project-top=../../'\'''
>>     sbindir='${exec_prefix}/sbin'
>>     sharedstatedir='${prefix}/com'
>>     sysconfdir='${prefix}/etc'
>>     target='bfin-unknown-rtems4.10'
>>     target_alias='bfin-rtems4.10'
>>     target_cpu='bfin'
>>     target_os='rtems4.10'
>>     target_vendor='unknown'
>>     ## confdefs.h. ##
>>     #define PACKAGE_NAME "rtems-c"
>>     #define PACKAGE_TARNAME "rtems-c"
>>     #define PACKAGE_VERSION "4.9.99.0"
>>     #define PACKAGE_STRING "rtems-c 4.9.99.0"
>>     #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
>>     configure: exit 0
>>     Making all in make
>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/make'
>>     make[1]: Nothing to be done for `all'.
>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/make'
>>     Making all in tools/build
>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>>     make  all-am
>>     make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>>     gcc -DHAVE_CONFIG_H -I. -I../../../rtems/tools/build     -g -O2 -MT
>>     cklength.o -MD -MP -MF .deps/cklength.Tpo -c -o cklength.o
>>     ../../../rtems/tools/build/cklength.c
>>     mv -f .deps/cklength.Tpo .deps/cklength.Po
>>     gcc  -g -O2   -o cklength cklength.o
>>     eolstrip.o -MD -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o
>>     ../../../rtems/tools/build/eolstrip.c
>>     mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
>>     gcc  -g -O2   -o eolstrip eolstrip.o
>>     packhex.o -MD -MP -MF .deps/packhex.Tpo -c -o packhex.o
>>     ../../../rtems/tools/build/packhex.c
>>     mv -f .deps/packhex.Tpo .deps/packhex.Po
>>     gcc  -g -O2   -o packhex packhex.o
>>     unhex.o -MD -MP -MF .deps/unhex.Tpo -c -o unhex.o
>>     ../../../rtems/tools/build/unhex.c
>>     mv -f .deps/unhex.Tpo .deps/unhex.Po
>>     gcc  -g -O2   -o unhex unhex.o
>>     rtems-bin2c.o -MD -MP -MF .deps/rtems-bin2c.Tpo -c -o rtems-bin2c.o
>>     ../../../rtems/tools/build/rtems-bin2c.c
>>     mv -f .deps/rtems-bin2c.Tpo .deps/rtems-bin2c.Po
>>     gcc  -g -O2   -o rtems-bin2c rtems-bin2c.o
>>     binpatch.o -MD -MP -MF .deps/binpatch.Tpo -c -o binpatch.o
>>     ../../../rtems/tools/build/binpatch.c
>>     mv -f .deps/binpatch.Tpo .deps/binpatch.Po
>>     gcc  -g -O2   -o binpatch binpatch.o
>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>     Making all in tools/cpu
>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>     Making all in generic
>>     `/home/els/rtems/bf537Stamp/tools/cpu/generic'
>>     make[2]: Nothing to be done for `all'.
>>     make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>     make[2]: Nothing to be done for `all-am'.
>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>     Making all in testsuites/tools
>>     `/home/els/rtems/bf537Stamp/testsuites/tools'
>>     `/home/els/rtems/bf537Stamp/testsuites/tools/generic'
>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>>     Making all in bfin-rtems4.10/c
>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>     Making all in .
>>     Configuring RTEMS_BSP=bf537Stamp
>>     checking for gmake... no
>>     checking for make... make
>>     checking build system type... i686-pc-linux-gnu
>>     checking host system type... bfin-unknown-rtems4.10
>>     checking rtems target cpu... bfin
>>     checking for a BSD-compatible install... /usr/bin/install -c
>>     checking whether build environment is sane... yes
>>     checking for a thread-safe mkdir -p... /bin/mkdir -p
>>     checking for gawk... no
>>     checking for mawk... mawk
>>     checking whether make sets $(MAKE)... yes
>>     checking for bfin-rtems4.10-strip... bfin-rtems4.10-strip
>>     checking whether to enable maintainer-specific portions of
>>     Makefiles... no
>>     checking for RTEMS_BSP... bf537Stamp
>>     checking for
>>     ../../../../rtems/c/src/../../bspkit/bfin/*/cfg/bf537Stamp.cfg... no
>>     checking for
>>     ../../../../rtems/c/src/../../make/custom/bf537Stamp.cfg... yes
>>     checking whether BSP supports networking... yes
>>     checking whether CPU supports libposix... disabled
>>     configure: setting up make/custom
>>     checking for
>>     checking for
>>     configure: creating make/bf537Stamp.cache
>>     make[3]: Entering directory
>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp'
>>     make[3]: Leaving directory
>>     checking for RTEMS_CPU_MODEL... bf537
>>     checking for RTEMS_BSP_FAMILY... (cached) bf537Stamp
>>     checking for CPU_CFLAGS... (cached)
>>     checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>>     checking for style of include used by make... GNU
>>     checking for bfin-rtems4.10-gcc... bfin-rtems4.10-gcc
>>     checking for bfin-rtems4.10-gcc... (cached) bfin-rtems4.10-gcc
>>     checking for C compiler default output file name...
>>     configure: error: in
>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp':
>>     configure: error: C compiler cannot create executables
>>     See `config.log' for more details.
>>     make[2]: *** [bf537Stamp] Error 1
>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>     make[1]: *** [all-recursive] Error 1
>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>     make: *** [all-recursive] Error 1
