Debian-host build error...
Ian Caddy ianc at goanna.iinet.net.au
Thu Jun 25 01:37:11 UTC 2009
Hi Ed,
Now I am also not an expert in this but from what I could find:
Depending on your version you might find that your latest version you
can get of libc is 2.3 not the needed 2.4.
What do you get from:
apt-cache show libc6
It should show you which version of glibc is installed.  I would guess
that it is 2.3.<something> and this is causing your problems.
Are you running the latest version of Debian?
regards,
Ian Caddy
Ed Sutter wrote:
> One more snippet of information...
> I figured I'd test to see if the problem was blackfin-tools related, so
> I installed the powerpc tools and got the exact same error...
> els:powerpc-rtems4.10-gcc --help
> powerpc-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not fou
> nd (required by powerpc-rtems4.10-gcc)
> Ed
> Ed Sutter wrote:
>> Daron & all,
>> Yep, that was a typo.  The PATH is correct; however, I hadnt' actually
>> tried the cross-compiler out manually, and there is an issue...
>> Forget about successful cross-compilation, there are shared libs it
>> can't find...
>> els:bfin-rtems4.10-gcc --help
>> bfin-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not found
>> (required by bfin-rtems4.10-gcc)
>> A little googling seems to indicate that this is a strange issue with Debian
>> because it happens with other tools.  Haven't figured out how to get around it
>> though.
>> Ed
>> Daron Chabot wrote:
>>> Hi Ed,
>>> Have not used alien to convert rpms to debs, but:
>>> Have you verified that your cross-compiler works ? You should get an
>>> "a.out" file from cross-compiling this:
>>>     int foo(void) { return 0; }
>>> Also, I noticed you specified "export PATH=/opt/rtems-4.9/bin:$PATH"...
>>> i assume the "rtems-4.9" was simply a typo, and your path actually
>>> points to the correct tool versions...
>>> -- dc
>>> On Wed, Jun 24, 2009 at 12:46 PM, Ed Sutter <esutter at alcatel-lucent.com
>>> <mailto:esutter at alcatel-lucent.com>> wrote:
>>>     Ian,
>>>     Thanks, here's more info...
>>>     I'm following the steps from the "Quick Start" wiki page.
>>>     First I got the prebuilt tools from:
>>>       http://www.rtems.org/ftp/pub/rtems/linux/4.10/fedora/10/i386/
>>>     I followed the Debian-specific instructions at:
>>>       http://www.rtems.com/wiki/index.php/RTEMS_Prebuilt_Tools
>>>     which talk about the "alien" tool and the conversion from .rpm to .deb.
>>>     All that appears to work just fine.
>>>     Then, referring to the "Example Application Compiling" page
>>>     I execute these steps...
>>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
>>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems
>>>      cd rtems
>>>      ./bootstrap
>>>      cd ..
>>>      mkdir bf537Stamp
>>>      cd bf537Stamp
>>>      ../rtems/configure --target=bfin-rtems4.10
>>>     --enable-rtemsbsp=bf537Stamp \
>>>        --enable-tests=samples --disable-posix --disable-itron
>>>      make all
>>>     The error occurs in the "make all" step.  It apparently runs yet another
>>>     configure down below, and that's the point where it chokes.  Attached
>>>     is the output of the "make all", as well as the config.log file that the
>>>     error in the make output is referring to.
>>>     Thanks for any help you can offer!  I'm bracing myself for being told
>>>     I'm doing something really stupid.  :-(
>>>     Ed
>>>     Ian Caddy wrote:
>>>         Hi Ed,
>>>         I am not really sure, but do you have any more details?
>>>         Such as when the error occurred, I assume during configure?
>>>         If so, did you look at the config.log output to see if it gave
>>>         any clues as to why it failed the check for being able to build
>>>         executables?
>>>         regards,
>>>         Ian Caddy
>>>         Ed Sutter wrote:
>>>             Folks,
>>>             Didn't get any responses on this, so I figured I'd try again...
>>>             When I reported this error, I was using pre-built tools from:
>>>                http://www.rtems.org/ftp/pub/rtems/linux/4.9/redhat/el5/i386/
>>>             then the other day I started over using:
>>>             The exact same error occurred, so I'm still clueless.
>>>             Even the "remotest" of suggestions at this point would not
>>>             be in vain
>>>             (yea, I'm begging) :-( otherwise, I suppose I have to hunt
>>>             down a different
>>>             Linux box (non-debian) to isolate this problem.
>>>             Thanks,
>>>             Ed
>>>             Ed Sutter wrote:
>>>                 Folks,
>>>                 I'm walking through the quick-start procedure for
>>>                 building the
>>>                 BF537Stamp BSP.  My development host is Debian, and I've
>>>                 gotten
>>>                 to the point (on the quick-start page) where it mentions
>>>                 the error:
>>>                 * If you experience a "C compiler cannot create
>>>                 executables" error,
>>>                 * try fixing your compiler by getting libc-dev
>>>                 I ran apt-get install libc-dev and got the following
>>>                 message:
>>>                 * root:apt-get install libc-dev
>>>                 * Reading package lists... Done
>>>                 * Building dependency tree... Done
>>>                 * Note, selecting libc6-dev instead of libc-dev
>>>                 * libc6-dev is already the newest version.
>>>                 * 0 upgraded, 0 newly installed, 0 to remove and 1 not
>>>                 upgraded.
>>>                 Anyone working with a Debian host that has had (and
>>>                 overcame) this
>>>                 problem?
>>>                 Thanks
>>>                 Ed
>>>                 _______________________________________________
>>>                 rtems-users mailing list
>>>                 rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>                 http://www.rtems.org/mailman/listinfo/rtems-users
>>>             No virus found in this incoming message.
>>>             Checked by AVG - www.avg.com <http://www.avg.com> Version:
>>>             8.5.375 / Virus Database: 270.12.90/2198 - Release Date:
>>>             06/23/09 17:54:00
>>>     This file contains any messages produced by compilers while
>>>     running configure, to aid debugging if configure makes a mistake.
>>>     It was created by rtems-c configure 4.9.99.0, which was
>>>     generated by GNU Autoconf 2.63.  Invocation command line was
>>>      $ ../../../rtems/c/configure --prefix=/opt/rtems-4.10
>>>     --host=bfin-rtems4.10 --build=i686-pc-linux-gnu
>>>     --target=bfin-rtems4.10 --enable-rtemsbsp=bf537Stamp
>>>     --with-target-subdir=bfin-rtems4.10
>>>     --exec-prefix=/opt/rtems-4.10/bfin-rtems4.10
>>>     --includedir=/opt/rtems-4.10/bfin-rtems4.10/include
>>>     --cache-file=/dev/null --srcdir=../../../rtems/c
>>>     ## Platform. ##
>>>     hostname = xpcelslinux1
>>>     uname -m = i686
>>>     uname -r = 2.6.18-6-486
>>>     uname -s = Linux
>>>     uname -v = #1 Mon May 4 23:59:22 UTC 2009
>>>     /usr/bin/uname -p = unknown
>>>     /bin/uname -X     = unknown
>>>     /bin/arch              = i686
>>>     /usr/bin/arch -k       = unknown
>>>     /usr/convex/getsysinfo = unknown
>>>     /usr/bin/hostinfo      = unknown
>>>     /bin/machine           = unknown
>>>     /usr/bin/oslevel       = unknown
>>>     /bin/universe          = unknown
>>>     PATH: /home/els/bin
>>>     PATH: /usr/local/bin
>>>     PATH: /usr/bin
>>>     PATH: /bin
>>>     PATH: /usr/games
>>>     PATH: /home/els/bin
>>>     PATH: /sbin
>>>     PATH: /opt/uClinux/bfin-elf/bin
>>>     PATH: /opt/uClinux/bfin-uclinux/bin
>>>     PATH: /opt/uClinux/bfin-linux-uclibc/bin
>>>     PATH: /opt/arm-2007q3/bin
>>>     PATH: /opt/rtems-4.10/bin
>>>     ## Core tests. ##
>>>     configure:1821: checking for gmake
>>>     configure:1851: result: no
>>>     configure:1821: checking for make
>>>     configure:1837: found /usr/bin/make
>>>     configure:1848: result: make
>>>     configure:1873: checking for RTEMS Version
>>>     configure:1875: result: 4.9.99.0
>>>     configure:1885: checking build system type
>>>     configure:1903: result: i686-pc-linux-gnu
>>>     configure:1925: checking host system type
>>>     configure:1940: result: bfin-unknown-rtems4.10
>>>     configure:1963: checking target system type
>>>     configure:1978: result: bfin-unknown-rtems4.10
>>>     configure:2006: checking rtems target cpu
>>>     configure:2029: result: bfin
>>>     configure:2049: checking for a BSD-compatible install
>>>     configure:2117: result: /usr/bin/install -c
>>>     configure:2128: checking whether build environment is sane
>>>     configure:2171: result: yes
>>>     configure:2196: checking for a thread-safe mkdir -p
>>>     configure:2235: result: /bin/mkdir -p
>>>     configure:2248: checking for gawk
>>>     configure:2278: result: no
>>>     configure:2248: checking for mawk
>>>     configure:2264: found /usr/bin/mawk
>>>     configure:2275: result: mawk
>>>     configure:2286: checking whether make sets $(MAKE)
>>>     configure:2308: result: yes
>>>     configure:2379: checking for bfin-rtems4.10-strip
>>>     configure:2395: found /opt/rtems-4.10/bin/bfin-rtems4.10-strip
>>>     configure:2406: result: bfin-rtems4.10-strip
>>>     configure:2483: checking whether to enable maintainer-specific
>>>     portions of Makefiles
>>>     configure:2492: result: no
>>>     configure:2593: checking for bf537Stamp.cfg
>>>     configure:2607: result: ../../../rtems/c/../make/custom/bf537Stamp.cfg
>>>     configure:2899: creating ./config.status
>>>     ## Running config.status. ##
>>>     This file was extended by rtems-c config.status 4.9.99.0, which was
>>>      CONFIG_FILES    =
>>>      CONFIG_HEADERS  =
>>>      CONFIG_LINKS    =
>>>      CONFIG_COMMANDS =
>>>      $ ./config.status
>>>     on xpcelslinux1
>>>     config.status:690: creating Makefile
>>>     ## Cache variables. ##
>>>     ac_cv_build=i686-pc-linux-gnu
>>>     ac_cv_env_build_alias_set=set
>>>     ac_cv_env_build_alias_value=i686-pc-linux-gnu
>>>     ac_cv_env_host_alias_set=set
>>>     ac_cv_env_host_alias_value=bfin-rtems4.10
>>>     ac_cv_env_target_alias_set=set
>>>     ac_cv_env_target_alias_value=bfin-rtems4.10
>>>     ac_cv_host=bfin-unknown-rtems4.10
>>>     ac_cv_path_install='/usr/bin/install -c'
>>>     ac_cv_path_mkdir=/bin/mkdir
>>>     ac_cv_prog_AWK=mawk
>>>     ac_cv_prog_MAKE=make
>>>     ac_cv_prog_STRIP=bfin-rtems4.10-strip
>>>     ac_cv_prog_make_make_set=yes
>>>     ac_cv_target=bfin-unknown-rtems4.10
>>>     ## Output variables. ##
>>>     ACLOCAL='${SHELL} /home/els/rtems/rtems/missing --run aclocal-1.10'
>>>     AMTAR='${SHELL} /home/els/rtems/rtems/missing --run tar'
>>>     AUTOCONF='${SHELL} /home/els/rtems/rtems/missing --run autoconf'
>>>     AUTOHEADER='${SHELL} /home/els/rtems/rtems/missing --run autoheader'
>>>     AUTOMAKE='${SHELL} /home/els/rtems/rtems/missing --run automake-1.10'
>>>     AWK='mawk'
>>>     CYGPATH_W='echo'
>>>     DEFS='-DPACKAGE_NAME=\"rtems-c\" -DPACKAGE_TARNAME=\"rtems-c\"
>>>     -DPACKAGE_VERSION=\"4.9.99.0\" -DPACKAGE_STRING=\"rtems-c\
>>>     4.9.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\"'
>>>     ECHO_C=''
>>>     ECHO_N='-n'
>>>     ECHO_T=''
>>>     INSTALL_DATA='${INSTALL} -m 644'
>>>     INSTALL_PROGRAM='${INSTALL}'
>>>     INSTALL_SCRIPT='${INSTALL}'
>>>     INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
>>>     LIBOBJS=''
>>>     LIBS=''
>>>     LTLIBOBJS=''
>>>     MAINT='#'
>>>     MAINTAINER_MODE_FALSE=''
>>>     MAINTAINER_MODE_TRUE='#'
>>>     MAKE='make'
>>>     MAKEINFO='${SHELL} /home/els/rtems/rtems/missing --run makeinfo'
>>>     MKDIR_P='/bin/mkdir -p'
>>>     PACKAGE='rtems-c'
>>>     PACKAGE_BUGREPORT='http://www.rtems.org/bugzilla'
>>>     PACKAGE_NAME='rtems-c'
>>>     PACKAGE_STRING='rtems-c 4.9.99.0'
>>>     PACKAGE_TARNAME='rtems-c'
>>>     PACKAGE_VERSION='4.9.99.0'
>>>     PATH_SEPARATOR=':'
>>>     PROJECT_ROOT='../$(top_builddir)'
>>>     PROJECT_TOPdir='../../$(top_builddir)'
>>>     RTEMS_BSP_LIST=' bf537Stamp'
>>>     RTEMS_CPU='bfin'
>>>     RTEMS_TOPdir='..'
>>>     SET_MAKE=''
>>>     SHELL='/bin/sh'
>>>     STRIP='bfin-rtems4.10-strip'
>>>     VERSION='4.9.99.0'
>>>     am__isrc=' -I$(srcdir)'
>>>     am__leading_dot='.'
>>>     am__tar='${AMTAR} chof - "$$tardir"'
>>>     am__untar='${AMTAR} xf -'
>>>     bindir='${exec_prefix}/bin'
>>>     build='i686-pc-linux-gnu'
>>>     build_alias='i686-pc-linux-gnu'
>>>     build_cpu='i686'
>>>     build_os='linux-gnu'
>>>     build_vendor='pc'
>>>     datadir='${datarootdir}'
>>>     datarootdir='${prefix}/share'
>>>     docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>>>     dvidir='${docdir}'
>>>     exec_prefix='/opt/rtems-4.10/bfin-rtems4.10'
>>>     host='bfin-unknown-rtems4.10'
>>>     host_alias='bfin-rtems4.10'
>>>     host_cpu='bfin'
>>>     host_os='rtems4.10'
>>>     host_vendor='unknown'
>>>     htmldir='${docdir}'
>>>     includedir='/opt/rtems-4.10/bfin-rtems4.10/include'
>>>     infodir='${datarootdir}/info'
>>>     install_sh='$(SHELL) /home/els/rtems/rtems/install-sh'
>>>     libdir='${exec_prefix}/lib'
>>>     libexecdir='${exec_prefix}/libexec'
>>>     localedir='${datarootdir}/locale'
>>>     localstatedir='${prefix}/var'
>>>     mandir='${datarootdir}/man'
>>>     mkdir_p='/bin/mkdir -p'
>>>     oldincludedir='/usr/include'
>>>     pdfdir='${docdir}'
>>>     prefix='/opt/rtems-4.10'
>>>     program_transform_name='s&^&bfin-rtems4.10-&'
>>>     psdir='${docdir}'
>>>     rtems_bsp_configure='../../../../rtems/c/src/configure
>>>      '\''--prefix=/opt/rtems-4.10'\'' '\''--host=bfin-rtems4.10'\''
>>>     '\''--build=i686-pc-linux-gnu'\'' '\''--target=bfin-rtems4.10'\''
>>>     '\''--enable-tests=samples'\'' '\''--disable-posix'\''
>>>     '\''--disable-itron'\'' '\''--with-target-subdir=bfin-rtems4.10'\''
>>>     '\''--exec-prefix=/opt/rtems-4.10/bfin-rtems4.10'\''
>>>     '\''--includedir=/opt/rtems-4.10/bfin-rtems4.10/include'\''
>>>     '\''build_alias=i686-pc-linux-gnu'\''
>>>     '\''host_alias=bfin-rtems4.10'\''
>>>     '\''target_alias=bfin-rtems4.10'\''
>>>     '\''--with-project-root=../../'\'' '\''--with-project-top=../../'\'''
>>>     sbindir='${exec_prefix}/sbin'
>>>     sharedstatedir='${prefix}/com'
>>>     sysconfdir='${prefix}/etc'
>>>     target='bfin-unknown-rtems4.10'
>>>     target_alias='bfin-rtems4.10'
>>>     target_cpu='bfin'
>>>     target_os='rtems4.10'
>>>     target_vendor='unknown'
>>>     ## confdefs.h. ##
>>>     #define PACKAGE_NAME "rtems-c"
>>>     #define PACKAGE_TARNAME "rtems-c"
>>>     #define PACKAGE_VERSION "4.9.99.0"
>>>     #define PACKAGE_STRING "rtems-c 4.9.99.0"
>>>     #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
>>>     configure: exit 0
>>>     Making all in make
>>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/make'
>>>     make[1]: Nothing to be done for `all'.
>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/make'
>>>     Making all in tools/build
>>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>>>     make  all-am
>>>     make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>>>     gcc -DHAVE_CONFIG_H -I. -I../../../rtems/tools/build     -g -O2 -MT
>>>     cklength.o -MD -MP -MF .deps/cklength.Tpo -c -o cklength.o
>>>     ../../../rtems/tools/build/cklength.c
>>>     mv -f .deps/cklength.Tpo .deps/cklength.Po
>>>     gcc  -g -O2   -o cklength cklength.o
>>>     eolstrip.o -MD -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o
>>>     ../../../rtems/tools/build/eolstrip.c
>>>     mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
>>>     gcc  -g -O2   -o eolstrip eolstrip.o
>>>     packhex.o -MD -MP -MF .deps/packhex.Tpo -c -o packhex.o
>>>     ../../../rtems/tools/build/packhex.c
>>>     mv -f .deps/packhex.Tpo .deps/packhex.Po
>>>     gcc  -g -O2   -o packhex packhex.o
>>>     unhex.o -MD -MP -MF .deps/unhex.Tpo -c -o unhex.o
>>>     ../../../rtems/tools/build/unhex.c
>>>     mv -f .deps/unhex.Tpo .deps/unhex.Po
>>>     gcc  -g -O2   -o unhex unhex.o
>>>     rtems-bin2c.o -MD -MP -MF .deps/rtems-bin2c.Tpo -c -o rtems-bin2c.o
>>>     ../../../rtems/tools/build/rtems-bin2c.c
>>>     mv -f .deps/rtems-bin2c.Tpo .deps/rtems-bin2c.Po
>>>     gcc  -g -O2   -o rtems-bin2c rtems-bin2c.o
>>>     binpatch.o -MD -MP -MF .deps/binpatch.Tpo -c -o binpatch.o
>>>     ../../../rtems/tools/build/binpatch.c
>>>     mv -f .deps/binpatch.Tpo .deps/binpatch.Po
>>>     gcc  -g -O2   -o binpatch binpatch.o
>>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>>     Making all in tools/cpu
>>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>     Making all in generic
>>>     `/home/els/rtems/bf537Stamp/tools/cpu/generic'
>>>     make[2]: Nothing to be done for `all'.
>>>     make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>     make[2]: Nothing to be done for `all-am'.
>>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>     Making all in testsuites/tools
>>>     `/home/els/rtems/bf537Stamp/testsuites/tools'
>>>     `/home/els/rtems/bf537Stamp/testsuites/tools/generic'
>>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>>>     Making all in bfin-rtems4.10/c
>>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>>     Making all in .
>>>     Configuring RTEMS_BSP=bf537Stamp
>>>     checking for gmake... no
>>>     checking for make... make
>>>     checking build system type... i686-pc-linux-gnu
>>>     checking host system type... bfin-unknown-rtems4.10
>>>     checking rtems target cpu... bfin
>>>     checking for a BSD-compatible install... /usr/bin/install -c
>>>     checking whether build environment is sane... yes
>>>     checking for a thread-safe mkdir -p... /bin/mkdir -p
>>>     checking for gawk... no
>>>     checking for mawk... mawk
>>>     checking whether make sets $(MAKE)... yes
>>>     checking for bfin-rtems4.10-strip... bfin-rtems4.10-strip
>>>     checking whether to enable maintainer-specific portions of
>>>     Makefiles... no
>>>     checking for RTEMS_BSP... bf537Stamp
>>>     checking for
>>>     ../../../../rtems/c/src/../../bspkit/bfin/*/cfg/bf537Stamp.cfg... no
>>>     checking for
>>>     ../../../../rtems/c/src/../../make/custom/bf537Stamp.cfg... yes
>>>     checking whether BSP supports networking... yes
>>>     checking whether CPU supports libposix... disabled
>>>     configure: setting up make/custom
>>>     checking for
>>>     checking for
>>>     configure: creating make/bf537Stamp.cache
>>>     make[3]: Entering directory
>>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp'
>>>     make[3]: Leaving directory
>>>     checking for RTEMS_CPU_MODEL... bf537
>>>     checking for RTEMS_BSP_FAMILY... (cached) bf537Stamp
>>>     checking for CPU_CFLAGS... (cached)
>>>     checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>>>     checking for style of include used by make... GNU
>>>     checking for bfin-rtems4.10-gcc... bfin-rtems4.10-gcc
>>>     checking for bfin-rtems4.10-gcc... (cached) bfin-rtems4.10-gcc
>>>     checking for C compiler default output file name...
>>>     configure: error: in
>>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp':
>>>     configure: error: C compiler cannot create executables
>>>     See `config.log' for more details.
>>>     make[2]: *** [bf537Stamp] Error 1
>>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>>     make[1]: *** [all-recursive] Error 1
>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>>     make: *** [all-recursive] Error 1
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9444 2634
