Debian-host build error...
Ed Sutter esutter at alcatel-lucent.com
Thu Jun 25 11:58:17 UTC 2009
Ian,
Well, you're right, output of apt-cache show libc6 shows...
    Source: glibc (2.3.6.ds1-13etch9)
    Version: 2.3.6.ds1-13etch9+b1
I *thought* I was running with the latest Debian.  I naively pull
down the updates whenever it says they're available...
els:cat /etc/issue
Debian GNU/Linux 4.0 \n \l
els:uname -a
Linux xpcelslinux1 2.6.18-6-486 #1 Mon May 4 23:59:22 UTC 2009 i686 GNU/Linux
I guess I gotta figure out how to update...
Thanks
Ed
Ian Caddy wrote:
> Hi Ed,
> Now I am also not an expert in this but from what I could find:
> Depending on your version you might find that your latest version you
> can get of libc is 2.3 not the needed 2.4.
> What do you get from:
> It should show you which version of glibc is installed.  I would guess
> that it is 2.3.<something> and this is causing your problems.
> Are you running the latest version of Debian?
> regards,
> Ian Caddy
> Ed Sutter wrote:
>> One more snippet of information...
>> I figured I'd test to see if the problem was blackfin-tools related, so
>> I installed the powerpc tools and got the exact same error...
>> els:powerpc-rtems4.10-gcc --help
>> powerpc-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version
>> `GLIBC_2.4' not fou
>> nd (required by powerpc-rtems4.10-gcc)
>> Ed
>> Ed Sutter wrote:
>>> Daron & all,
>>> Yep, that was a typo.  The PATH is correct; however, I hadnt' actually
>>> tried the cross-compiler out manually, and there is an issue...
>>> Forget about successful cross-compilation, there are shared libs it
>>> can't find...
>>> els:bfin-rtems4.10-gcc --help
>>> bfin-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4'
>>> not found
>>> (required by bfin-rtems4.10-gcc)
>>> A little googling seems to indicate that this is a strange issue with
>>> Debian
>>> because it happens with other tools.  Haven't figured out how to get
>>> around it
>>> though.
>>> Ed
>>> Daron Chabot wrote:
>>>> Hi Ed,
>>>> Have not used alien to convert rpms to debs, but:
>>>> Have you verified that your cross-compiler works ? You should get an
>>>> "a.out" file from cross-compiling this:
>>>>     int foo(void) { return 0; }
>>>> Also, I noticed you specified "export
>>>> PATH=/opt/rtems-4.9/bin:$PATH"... i assume the "rtems-4.9" was
>>>> simply a typo, and your path actually points to the correct tool
>>>> versions...
>>>> -- dc
>>>> On Wed, Jun 24, 2009 at 12:46 PM, Ed Sutter
>>>> <esutter at alcatel-lucent.com <mailto:esutter at alcatel-lucent.com>> wrote:
>>>>     Ian,
>>>>     Thanks, here's more info...
>>>>     I'm following the steps from the "Quick Start" wiki page.
>>>>     First I got the prebuilt tools from:
>>>>       http://www.rtems.org/ftp/pub/rtems/linux/4.10/fedora/10/i386/
>>>>     I followed the Debian-specific instructions at:
>>>>       http://www.rtems.com/wiki/index.php/RTEMS_Prebuilt_Tools
>>>>     which talk about the "alien" tool and the conversion from .rpm
>>>> to .deb.
>>>>     All that appears to work just fine.
>>>>     Then, referring to the "Example Application Compiling" page
>>>>     I execute these steps...
>>>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
>>>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems
>>>>      cd rtems
>>>>      export PATH=/opt/rtems-4.9/bin:$PATH
>>>>      ./bootstrap
>>>>      cd ..
>>>>      mkdir bf537Stamp
>>>>      cd bf537Stamp
>>>>      ../rtems/configure --target=bfin-rtems4.10
>>>>     --enable-rtemsbsp=bf537Stamp \
>>>>        --enable-tests=samples --disable-posix --disable-itron
>>>>      make all
>>>>     The error occurs in the "make all" step.  It apparently runs yet
>>>> another
>>>>     configure down below, and that's the point where it chokes.
>>>> Attached
>>>>     is the output of the "make all", as well as the config.log file
>>>> that the
>>>>     error in the make output is referring to.
>>>>     Thanks for any help you can offer!  I'm bracing myself for being
>>>> told
>>>>     I'm doing something really stupid.  :-(
>>>>     Ed
>>>>     Ian Caddy wrote:
>>>>         Hi Ed,
>>>>         I am not really sure, but do you have any more details?
>>>>         Such as when the error occurred, I assume during configure?
>>>>         If so, did you look at the config.log output to see if it gave
>>>>         any clues as to why it failed the check for being able to build
>>>>         executables?
>>>>         regards,
>>>>         Ian Caddy
>>>>         Ed Sutter wrote:
>>>>             Folks,
>>>>             Didn't get any responses on this, so I figured I'd try
>>>> again...
>>>>             When I reported this error, I was using pre-built tools
>>>> from:
>>>> http://www.rtems.org/ftp/pub/rtems/linux/4.9/redhat/el5/i386/
>>>>             then the other day I started over using:
>>>>                            The exact same error occurred, so I'm
>>>> still clueless.
>>>>             Even the "remotest" of suggestions at this point would not
>>>>             be in vain
>>>>             (yea, I'm begging) :-( otherwise, I suppose I have to hunt
>>>>             down a different
>>>>             Linux box (non-debian) to isolate this problem.
>>>>             Thanks,
>>>>             Ed
>>>>             Ed Sutter wrote:
>>>>                 Folks,
>>>>                 I'm walking through the quick-start procedure for
>>>>                 building the
>>>>                 BF537Stamp BSP.  My development host is Debian, and
>>>> I've
>>>>                 gotten
>>>>                 to the point (on the quick-start page) where it
>>>> mentions
>>>>                 the error:
>>>>                 * If you experience a "C compiler cannot create
>>>>                 executables" error,
>>>>                 * try fixing your compiler by getting libc-dev
>>>>                 I ran apt-get install libc-dev and got the following
>>>>                 message:
>>>>                 * root:apt-get install libc-dev
>>>>                 * Reading package lists... Done
>>>>                 * Building dependency tree... Done
>>>>                 * Note, selecting libc6-dev instead of libc-dev
>>>>                 * libc6-dev is already the newest version.
>>>>                 * 0 upgraded, 0 newly installed, 0 to remove and 1 not
>>>>                 upgraded.
>>>>                 Anyone working with a Debian host that has had (and
>>>>                 overcame) this
>>>>                 problem?
>>>>                 Thanks
>>>>                 Ed
>>>>                 _______________________________________________
>>>>                 rtems-users mailing list
>>>>                 rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>>                 http://www.rtems.org/mailman/listinfo/rtems-users
>>>>             No virus found in this incoming message.
>>>>             Checked by AVG - www.avg.com <http://www.avg.com> Version:
>>>>             8.5.375 / Virus Database: 270.12.90/2198 - Release Date:
>>>>             06/23/09 17:54:00
>>>>     This file contains any messages produced by compilers while
>>>>     running configure, to aid debugging if configure makes a mistake.
>>>>     It was created by rtems-c configure 4.9.99.0, which was
>>>>     generated by GNU Autoconf 2.63.  Invocation command line was
>>>>      $ ../../../rtems/c/configure --prefix=/opt/rtems-4.10
>>>>     --host=bfin-rtems4.10 --build=i686-pc-linux-gnu
>>>>     --target=bfin-rtems4.10 --enable-rtemsbsp=bf537Stamp
>>>>     --with-target-subdir=bfin-rtems4.10
>>>>     --exec-prefix=/opt/rtems-4.10/bfin-rtems4.10
>>>>     --includedir=/opt/rtems-4.10/bfin-rtems4.10/include
>>>>     --cache-file=/dev/null --srcdir=../../../rtems/c
>>>>     ## Platform. ##
>>>>     hostname = xpcelslinux1
>>>>     uname -m = i686
>>>>     uname -r = 2.6.18-6-486
>>>>     uname -s = Linux
>>>>     uname -v = #1 Mon May 4 23:59:22 UTC 2009
>>>>     /usr/bin/uname -p = unknown
>>>>     /bin/uname -X     = unknown
>>>>     /bin/arch              = i686
>>>>     /usr/bin/arch -k       = unknown
>>>>     /usr/convex/getsysinfo = unknown
>>>>     /usr/bin/hostinfo      = unknown
>>>>     /bin/machine           = unknown
>>>>     /usr/bin/oslevel       = unknown
>>>>     /bin/universe          = unknown
>>>>     PATH: /home/els/bin
>>>>     PATH: /usr/local/bin
>>>>     PATH: /usr/bin
>>>>     PATH: /bin
>>>>     PATH: /usr/games
>>>>     PATH: /home/els/bin
>>>>     PATH: /sbin
>>>>     PATH: /opt/uClinux/bfin-elf/bin
>>>>     PATH: /opt/uClinux/bfin-uclinux/bin
>>>>     PATH: /opt/uClinux/bfin-linux-uclibc/bin
>>>>     PATH: /opt/arm-2007q3/bin
>>>>     PATH: /opt/rtems-4.10/bin
>>>>     ## Core tests. ##
>>>>     configure:1821: checking for gmake
>>>>     configure:1851: result: no
>>>>     configure:1821: checking for make
>>>>     configure:1837: found /usr/bin/make
>>>>     configure:1848: result: make
>>>>     configure:1873: checking for RTEMS Version
>>>>     configure:1875: result: 4.9.99.0
>>>>     configure:1885: checking build system type
>>>>     configure:1903: result: i686-pc-linux-gnu
>>>>     configure:1925: checking host system type
>>>>     configure:1940: result: bfin-unknown-rtems4.10
>>>>     configure:1963: checking target system type
>>>>     configure:1978: result: bfin-unknown-rtems4.10
>>>>     configure:2006: checking rtems target cpu
>>>>     configure:2029: result: bfin
>>>>     configure:2049: checking for a BSD-compatible install
>>>>     configure:2117: result: /usr/bin/install -c
>>>>     configure:2128: checking whether build environment is sane
>>>>     configure:2171: result: yes
>>>>     configure:2196: checking for a thread-safe mkdir -p
>>>>     configure:2235: result: /bin/mkdir -p
>>>>     configure:2248: checking for gawk
>>>>     configure:2278: result: no
>>>>     configure:2248: checking for mawk
>>>>     configure:2264: found /usr/bin/mawk
>>>>     configure:2275: result: mawk
>>>>     configure:2286: checking whether make sets $(MAKE)
>>>>     configure:2308: result: yes
>>>>     configure:2379: checking for bfin-rtems4.10-strip
>>>>     configure:2395: found /opt/rtems-4.10/bin/bfin-rtems4.10-strip
>>>>     configure:2406: result: bfin-rtems4.10-strip
>>>>     configure:2483: checking whether to enable maintainer-specific
>>>>     portions of Makefiles
>>>>     configure:2492: result: no
>>>>     configure:2593: checking for bf537Stamp.cfg
>>>>     configure:2607: result:
>>>> ../../../rtems/c/../make/custom/bf537Stamp.cfg
>>>>     configure:2899: creating ./config.status
>>>>     ## Running config.status. ##
>>>>     This file was extended by rtems-c config.status 4.9.99.0, which was
>>>>      CONFIG_FILES    =
>>>>      CONFIG_HEADERS  =
>>>>      CONFIG_LINKS    =
>>>>      CONFIG_COMMANDS =
>>>>      $ ./config.status
>>>>     on xpcelslinux1
>>>>     config.status:690: creating Makefile
>>>>     ## Cache variables. ##
>>>>     ac_cv_build=i686-pc-linux-gnu
>>>>     ac_cv_env_build_alias_set=set
>>>>     ac_cv_env_build_alias_value=i686-pc-linux-gnu
>>>>     ac_cv_env_host_alias_set=set
>>>>     ac_cv_env_host_alias_value=bfin-rtems4.10
>>>>     ac_cv_env_target_alias_set=set
>>>>     ac_cv_env_target_alias_value=bfin-rtems4.10
>>>>     ac_cv_host=bfin-unknown-rtems4.10
>>>>     ac_cv_path_install='/usr/bin/install -c'
>>>>     ac_cv_path_mkdir=/bin/mkdir
>>>>     ac_cv_prog_AWK=mawk
>>>>     ac_cv_prog_MAKE=make
>>>>     ac_cv_prog_STRIP=bfin-rtems4.10-strip
>>>>     ac_cv_prog_make_make_set=yes
>>>>     ac_cv_target=bfin-unknown-rtems4.10
>>>>     ## Output variables. ##
>>>>     ACLOCAL='${SHELL} /home/els/rtems/rtems/missing --run aclocal-1.10'
>>>>     AMTAR='${SHELL} /home/els/rtems/rtems/missing --run tar'
>>>>     AUTOCONF='${SHELL} /home/els/rtems/rtems/missing --run autoconf'
>>>>     AUTOHEADER='${SHELL} /home/els/rtems/rtems/missing --run
>>>> autoheader'
>>>>     AUTOMAKE='${SHELL} /home/els/rtems/rtems/missing --run
>>>> automake-1.10'
>>>>     AWK='mawk'
>>>>     CYGPATH_W='echo'
>>>>     DEFS='-DPACKAGE_NAME=\"rtems-c\" -DPACKAGE_TARNAME=\"rtems-c\"
>>>>     -DPACKAGE_VERSION=\"4.9.99.0\" -DPACKAGE_STRING=\"rtems-c\
>>>>     4.9.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\"'
>>>>     ECHO_C=''
>>>>     ECHO_N='-n'
>>>>     ECHO_T=''
>>>>     INSTALL_DATA='${INSTALL} -m 644'
>>>>     INSTALL_PROGRAM='${INSTALL}'
>>>>     INSTALL_SCRIPT='${INSTALL}'
>>>>     INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
>>>>     LIBOBJS=''
>>>>     LIBS=''
>>>>     LTLIBOBJS=''
>>>>     MAINT='#'
>>>>     MAINTAINER_MODE_FALSE=''
>>>>     MAINTAINER_MODE_TRUE='#'
>>>>     MAKE='make'
>>>>     MAKEINFO='${SHELL} /home/els/rtems/rtems/missing --run makeinfo'
>>>>     MKDIR_P='/bin/mkdir -p'
>>>>     PACKAGE='rtems-c'
>>>>     PACKAGE_BUGREPORT='http://www.rtems.org/bugzilla'
>>>>     PACKAGE_NAME='rtems-c'
>>>>     PACKAGE_STRING='rtems-c 4.9.99.0'
>>>>     PACKAGE_TARNAME='rtems-c'
>>>>     PACKAGE_VERSION='4.9.99.0'
>>>>     PATH_SEPARATOR=':'
>>>>     PROJECT_ROOT='../$(top_builddir)'
>>>>     PROJECT_TOPdir='../../$(top_builddir)'
>>>>     RTEMS_BSP_LIST=' bf537Stamp'
>>>>     RTEMS_CPU='bfin'
>>>>     RTEMS_TOPdir='..'
>>>>     SET_MAKE=''
>>>>     SHELL='/bin/sh'
>>>>     STRIP='bfin-rtems4.10-strip'
>>>>     VERSION='4.9.99.0'
>>>>     am__isrc=' -I$(srcdir)'
>>>>     am__leading_dot='.'
>>>>     am__tar='${AMTAR} chof - "$$tardir"'
>>>>     am__untar='${AMTAR} xf -'
>>>>     bindir='${exec_prefix}/bin'
>>>>     build='i686-pc-linux-gnu'
>>>>     build_alias='i686-pc-linux-gnu'
>>>>     build_cpu='i686'
>>>>     build_os='linux-gnu'
>>>>     build_vendor='pc'
>>>>     datadir='${datarootdir}'
>>>>     datarootdir='${prefix}/share'
>>>>     docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>>>>     dvidir='${docdir}'
>>>>     exec_prefix='/opt/rtems-4.10/bfin-rtems4.10'
>>>>     host='bfin-unknown-rtems4.10'
>>>>     host_alias='bfin-rtems4.10'
>>>>     host_cpu='bfin'
>>>>     host_os='rtems4.10'
>>>>     host_vendor='unknown'
>>>>     htmldir='${docdir}'
>>>>     includedir='/opt/rtems-4.10/bfin-rtems4.10/include'
>>>>     infodir='${datarootdir}/info'
>>>>     install_sh='$(SHELL) /home/els/rtems/rtems/install-sh'
>>>>     libdir='${exec_prefix}/lib'
>>>>     libexecdir='${exec_prefix}/libexec'
>>>>     localedir='${datarootdir}/locale'
>>>>     localstatedir='${prefix}/var'
>>>>     mandir='${datarootdir}/man'
>>>>     mkdir_p='/bin/mkdir -p'
>>>>     oldincludedir='/usr/include'
>>>>     pdfdir='${docdir}'
>>>>     prefix='/opt/rtems-4.10'
>>>>     program_transform_name='s&^&bfin-rtems4.10-&'
>>>>     psdir='${docdir}'
>>>>     rtems_bsp_configure='../../../../rtems/c/src/configure
>>>>      '\''--prefix=/opt/rtems-4.10'\'' '\''--host=bfin-rtems4.10'\''
>>>>     '\''--build=i686-pc-linux-gnu'\'' '\''--target=bfin-rtems4.10'\''
>>>>     '\''--enable-tests=samples'\'' '\''--disable-posix'\''
>>>>     '\''--disable-itron'\'' '\''--with-target-subdir=bfin-rtems4.10'\''
>>>>     '\''--exec-prefix=/opt/rtems-4.10/bfin-rtems4.10'\''
>>>>     '\''--includedir=/opt/rtems-4.10/bfin-rtems4.10/include'\''
>>>>     '\''build_alias=i686-pc-linux-gnu'\''
>>>>     '\''host_alias=bfin-rtems4.10'\''
>>>>     '\''target_alias=bfin-rtems4.10'\''
>>>>     '\''--with-project-root=../../'\''
>>>> '\''--with-project-top=../../'\'''
>>>>     sbindir='${exec_prefix}/sbin'
>>>>     sharedstatedir='${prefix}/com'
>>>>     sysconfdir='${prefix}/etc'
>>>>     target='bfin-unknown-rtems4.10'
>>>>     target_alias='bfin-rtems4.10'
>>>>     target_cpu='bfin'
>>>>     target_os='rtems4.10'
>>>>     target_vendor='unknown'
>>>>     ## confdefs.h. ##
>>>>     #define PACKAGE_NAME "rtems-c"
>>>>     #define PACKAGE_TARNAME "rtems-c"
>>>>     #define PACKAGE_VERSION "4.9.99.0"
>>>>     #define PACKAGE_STRING "rtems-c 4.9.99.0"
>>>>     #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
>>>>     configure: exit 0
>>>>     Making all in make
>>>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/make'
>>>>     make[1]: Nothing to be done for `all'.
>>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/make'
>>>>     Making all in tools/build
>>>> `/home/els/rtems/bf537Stamp/tools/build'
>>>>     make  all-am
>>>>     make[2]: Entering directory
>>>>     gcc -DHAVE_CONFIG_H -I. -I../../../rtems/tools/build     -g -O2 -MT
>>>>     cklength.o -MD -MP -MF .deps/cklength.Tpo -c -o cklength.o
>>>>     ../../../rtems/tools/build/cklength.c
>>>>     mv -f .deps/cklength.Tpo .deps/cklength.Po
>>>>     gcc  -g -O2   -o cklength cklength.o
>>>>     eolstrip.o -MD -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o
>>>>     ../../../rtems/tools/build/eolstrip.c
>>>>     mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
>>>>     gcc  -g -O2   -o eolstrip eolstrip.o
>>>>     packhex.o -MD -MP -MF .deps/packhex.Tpo -c -o packhex.o
>>>>     ../../../rtems/tools/build/packhex.c
>>>>     mv -f .deps/packhex.Tpo .deps/packhex.Po
>>>>     gcc  -g -O2   -o packhex packhex.o
>>>>     unhex.o -MD -MP -MF .deps/unhex.Tpo -c -o unhex.o
>>>>     ../../../rtems/tools/build/unhex.c
>>>>     mv -f .deps/unhex.Tpo .deps/unhex.Po
>>>>     gcc  -g -O2   -o unhex unhex.o
>>>>     rtems-bin2c.o -MD -MP -MF .deps/rtems-bin2c.Tpo -c -o rtems-bin2c.o
>>>>     ../../../rtems/tools/build/rtems-bin2c.c
>>>>     mv -f .deps/rtems-bin2c.Tpo .deps/rtems-bin2c.Po
>>>>     gcc  -g -O2   -o rtems-bin2c rtems-bin2c.o
>>>>     binpatch.o -MD -MP -MF .deps/binpatch.Tpo -c -o binpatch.o
>>>>     ../../../rtems/tools/build/binpatch.c
>>>>     mv -f .deps/binpatch.Tpo .deps/binpatch.Po
>>>>     gcc  -g -O2   -o binpatch binpatch.o
>>>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>>>     Making all in tools/cpu
>>>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>     Making all in generic
>>>>     `/home/els/rtems/bf537Stamp/tools/cpu/generic'
>>>>     make[2]: Nothing to be done for `all'.
>>>>     make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>     make[2]: Nothing to be done for `all-am'.
>>>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>     Making all in testsuites/tools
>>>>     `/home/els/rtems/bf537Stamp/testsuites/tools'
>>>>     `/home/els/rtems/bf537Stamp/testsuites/tools/generic'
>>>>     Making all in bfin-rtems4.10/c
>>>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>>>     Making all in .
>>>>     Configuring RTEMS_BSP=bf537Stamp
>>>>     checking for gmake... no
>>>>     checking for make... make
>>>>     checking build system type... i686-pc-linux-gnu
>>>>     checking host system type... bfin-unknown-rtems4.10
>>>>     checking rtems target cpu... bfin
>>>>     checking for a BSD-compatible install... /usr/bin/install -c
>>>>     checking whether build environment is sane... yes
>>>>     checking for a thread-safe mkdir -p... /bin/mkdir -p
>>>>     checking for gawk... no
>>>>     checking for mawk... mawk
>>>>     checking whether make sets $(MAKE)... yes
>>>>     checking for bfin-rtems4.10-strip... bfin-rtems4.10-strip
>>>>     checking whether to enable maintainer-specific portions of
>>>>     Makefiles... no
>>>>     checking for RTEMS_BSP... bf537Stamp
>>>>     checking for
>>>> ../../../../rtems/c/src/../../bspkit/bfin/*/cfg/bf537Stamp.cfg... no
>>>>     checking for
>>>>     ../../../../rtems/c/src/../../make/custom/bf537Stamp.cfg... yes
>>>>     checking whether BSP supports networking... yes
>>>>     checking whether CPU supports libposix... disabled
>>>>     configure: setting up make/custom
>>>>     checking for
>>>>     checking for
>>>>     configure: creating make/bf537Stamp.cache
>>>>     make[3]: Entering directory
>>>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp'
>>>>     make[3]: Leaving directory
>>>>     checking for RTEMS_CPU_MODEL... bf537
>>>>     checking for RTEMS_BSP_FAMILY... (cached) bf537Stamp
>>>>     checking for CPU_CFLAGS... (cached)
>>>>     checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>>>>     checking for style of include used by make... GNU
>>>>     checking for bfin-rtems4.10-gcc... bfin-rtems4.10-gcc
>>>>     checking for bfin-rtems4.10-gcc... (cached) bfin-rtems4.10-gcc
>>>>     checking for C compiler default output file name...
>>>>     configure: error: in
>>>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp':
>>>>     configure: error: C compiler cannot create executables
>>>>     See `config.log' for more details.
>>>>     make[2]: *** [bf537Stamp] Error 1
>>>>     make[1]: *** [all-recursive] Error 1
>>>>     make: *** [all-recursive] Error 1
