Debian-host build error...
Ed Sutter
esutter at alcatel-lucent.com
Thu Jun 25 12:00:27 UTC 2009
Alexandre,
Yep, that's the version I'm running...
Didn't realize it was out-of-date.
I thought the auto-updates took care of that for me.
Thanks,
Ed
Alexandre Constantino wrote:
> Hi,
> at this point I don't have much to add, since the cause of the problem was determined.
> Ed, you are running some ancient version of Debian.
> kernel 2.6.18 and libc6 2.3 (or older) are... old.
> Upgrade your distro to the latest stable version of Debian and you should solve your problems.
> I've been running Debian for a few years and it works fine (as good as a linux system can anyway ;))
> Best regards,
> Alexandre
> On Thursday 25 June 2009, Ian Caddy wrote:
>> Hi Ed,
>> Now I am also not an expert in this but from what I could find:
>> Depending on your version you might find that your latest version you
>> can get of libc is 2.3 not the needed 2.4.
>> What do you get from:
>> apt-cache show libc6
>> It should show you which version of glibc is installed. I would guess
>> that it is 2.3.<something> and this is causing your problems.
>> Are you running the latest version of Debian?
>> regards,
>> Ian Caddy
>> Ed Sutter wrote:
>>> One more snippet of information...
>>> I figured I'd test to see if the problem was blackfin-tools related, so
>>> I installed the powerpc tools and got the exact same error...
>>> els:powerpc-rtems4.10-gcc --help
>>> powerpc-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not fou
>>> nd (required by powerpc-rtems4.10-gcc)
>>> Ed
>>> Ed Sutter wrote:
>>>> Daron & all,
>>>> Yep, that was a typo. The PATH is correct; however, I hadnt' actually
>>>> tried the cross-compiler out manually, and there is an issue...
>>>> Forget about successful cross-compilation, there are shared libs it
>>>> can't find...
>>>> els:bfin-rtems4.10-gcc --help
>>>> bfin-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not found
>>>> (required by bfin-rtems4.10-gcc)
>>>> A little googling seems to indicate that this is a strange issue with Debian
>>>> because it happens with other tools. Haven't figured out how to get around it
>>>> though.
>>>> Ed
>>>> Daron Chabot wrote:
>>>>> Hi Ed,
>>>>> Have not used alien to convert rpms to debs, but:
>>>>> Have you verified that your cross-compiler works ? You should get an
>>>>> "a.out" file from cross-compiling this:
>>>>> int foo(void) { return 0; }
>>>>> Also, I noticed you specified "export PATH=/opt/rtems-4.9/bin:$PATH"...
>>>>> i assume the "rtems-4.9" was simply a typo, and your path actually
>>>>> points to the correct tool versions...
>>>>> -- dc
>>>>> On Wed, Jun 24, 2009 at 12:46 PM, Ed Sutter <esutter at alcatel-lucent.com
>>>>> <mailto:esutter at alcatel-lucent.com>> wrote:
>>>>> Ian,
>>>>> Thanks, here's more info...
>>>>> I'm following the steps from the "Quick Start" wiki page.
>>>>> First I got the prebuilt tools from:
>>>>> http://www.rtems.org/ftp/pub/rtems/linux/4.10/fedora/10/i386/
>>>>> I followed the Debian-specific instructions at:
>>>>> http://www.rtems.com/wiki/index.php/RTEMS_Prebuilt_Tools
>>>>> which talk about the "alien" tool and the conversion from .rpm to .deb.
>>>>> All that appears to work just fine.
>>>>> Then, referring to the "Example Application Compiling" page
>>>>> I execute these steps...
>>>>> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
>>>>> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems
>>>>> cd rtems
>>>>> ./bootstrap
>>>>> cd ..
>>>>> mkdir bf537Stamp
>>>>> cd bf537Stamp
>>>>> ../rtems/configure --target=bfin-rtems4.10
>>>>> --enable-rtemsbsp=bf537Stamp \
>>>>> --enable-tests=samples --disable-posix --disable-itron
>>>>> make all
>>>>> The error occurs in the "make all" step. It apparently runs yet another
>>>>> configure down below, and that's the point where it chokes. Attached
>>>>> is the output of the "make all", as well as the config.log file that the
>>>>> error in the make output is referring to.
>>>>> Thanks for any help you can offer! I'm bracing myself for being told
>>>>> I'm doing something really stupid. :-(
>>>>> Ed
>>>>> Ian Caddy wrote:
>>>>> Hi Ed,
>>>>> I am not really sure, but do you have any more details?
>>>>> Such as when the error occurred, I assume during configure?
>>>>> If so, did you look at the config.log output to see if it gave
>>>>> any clues as to why it failed the check for being able to build
>>>>> executables?
>>>>> regards,
>>>>> Ian Caddy
>>>>> Ed Sutter wrote:
>>>>> Folks,
>>>>> Didn't get any responses on this, so I figured I'd try again...
>>>>> When I reported this error, I was using pre-built tools from:
>>>>> http://www.rtems.org/ftp/pub/rtems/linux/4.9/redhat/el5/i386/
>>>>> then the other day I started over using:
>>>>> The exact same error occurred, so I'm still clueless.
>>>>> Even the "remotest" of suggestions at this point would not
>>>>> be in vain
>>>>> (yea, I'm begging) :-( otherwise, I suppose I have to hunt
>>>>> down a different
>>>>> Linux box (non-debian) to isolate this problem.
>>>>> Thanks,
>>>>> Ed
>>>>> Ed Sutter wrote:
>>>>> Folks,
>>>>> I'm walking through the quick-start procedure for
>>>>> building the
>>>>> BF537Stamp BSP. My development host is Debian, and I've
>>>>> gotten
>>>>> to the point (on the quick-start page) where it mentions
>>>>> the error:
>>>>> * If you experience a "C compiler cannot create
>>>>> executables" error,
>>>>> * try fixing your compiler by getting libc-dev
>>>>> I ran apt-get install libc-dev and got the following
>>>>> message:
>>>>> * root:apt-get install libc-dev
>>>>> * Reading package lists... Done
>>>>> * Building dependency tree... Done
>>>>> * Note, selecting libc6-dev instead of libc-dev
>>>>> * libc6-dev is already the newest version.
>>>>> * 0 upgraded, 0 newly installed, 0 to remove and 1 not
>>>>> upgraded.
>>>>> Anyone working with a Debian host that has had (and
>>>>> overcame) this
>>>>> problem?
>>>>> Thanks
>>>>> Ed
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>> No virus found in this incoming message.
>>>>> Checked by AVG - www.avg.com <http://www.avg.com> Version:
>>>>> 8.5.375 / Virus Database: 270.12.90/2198 - Release Date:
>>>>> 06/23/09 17:54:00
>>>>> This file contains any messages produced by compilers while
>>>>> running configure, to aid debugging if configure makes a mistake.
>>>>> It was created by rtems-c configure 4.9.99.0, which was
>>>>> generated by GNU Autoconf 2.63. Invocation command line was
>>>>> $ ../../../rtems/c/configure --prefix=/opt/rtems-4.10
>>>>> --host=bfin-rtems4.10 --build=i686-pc-linux-gnu
>>>>> --target=bfin-rtems4.10 --enable-rtemsbsp=bf537Stamp
>>>>> --with-target-subdir=bfin-rtems4.10
>>>>> --exec-prefix=/opt/rtems-4.10/bfin-rtems4.10
>>>>> --includedir=/opt/rtems-4.10/bfin-rtems4.10/include
>>>>> --cache-file=/dev/null --srcdir=../../../rtems/c
>>>>> ## Platform. ##
>>>>> hostname = xpcelslinux1
>>>>> uname -m = i686
>>>>> uname -r = 2.6.18-6-486
>>>>> uname -s = Linux
>>>>> uname -v = #1 Mon May 4 23:59:22 UTC 2009
>>>>> /usr/bin/uname -p = unknown
>>>>> /bin/uname -X = unknown
>>>>> /bin/arch = i686
>>>>> /usr/bin/arch -k = unknown
>>>>> /usr/convex/getsysinfo = unknown
>>>>> /usr/bin/hostinfo = unknown
>>>>> /bin/machine = unknown
>>>>> /usr/bin/oslevel = unknown
>>>>> /bin/universe = unknown
>>>>> PATH: /home/els/bin
>>>>> PATH: /usr/local/bin
>>>>> PATH: /usr/bin
>>>>> PATH: /bin
>>>>> PATH: /usr/games
>>>>> PATH: /home/els/bin
>>>>> PATH: /sbin
>>>>> PATH: /opt/uClinux/bfin-elf/bin
>>>>> PATH: /opt/uClinux/bfin-uclinux/bin
>>>>> PATH: /opt/uClinux/bfin-linux-uclibc/bin
>>>>> PATH: /opt/arm-2007q3/bin
>>>>> PATH: /opt/rtems-4.10/bin
>>>>> ## Core tests. ##
>>>>> configure:1821: checking for gmake
>>>>> configure:1851: result: no
>>>>> configure:1821: checking for make
>>>>> configure:1837: found /usr/bin/make
>>>>> configure:1848: result: make
>>>>> configure:1873: checking for RTEMS Version
>>>>> configure:1875: result: 4.9.99.0
>>>>> configure:1885: checking build system type
>>>>> configure:1903: result: i686-pc-linux-gnu
>>>>> configure:1925: checking host system type
>>>>> configure:1940: result: bfin-unknown-rtems4.10
>>>>> configure:1963: checking target system type
>>>>> configure:1978: result: bfin-unknown-rtems4.10
>>>>> configure:2006: checking rtems target cpu
>>>>> configure:2029: result: bfin
>>>>> configure:2049: checking for a BSD-compatible install
>>>>> configure:2117: result: /usr/bin/install -c
>>>>> configure:2128: checking whether build environment is sane
>>>>> configure:2171: result: yes
>>>>> configure:2196: checking for a thread-safe mkdir -p
>>>>> configure:2235: result: /bin/mkdir -p
>>>>> configure:2248: checking for gawk
>>>>> configure:2278: result: no
>>>>> configure:2248: checking for mawk
>>>>> configure:2264: found /usr/bin/mawk
>>>>> configure:2275: result: mawk
>>>>> configure:2286: checking whether make sets $(MAKE)
>>>>> configure:2308: result: yes
>>>>> configure:2379: checking for bfin-rtems4.10-strip
>>>>> configure:2395: found /opt/rtems-4.10/bin/bfin-rtems4.10-strip
>>>>> configure:2406: result: bfin-rtems4.10-strip
>>>>> configure:2483: checking whether to enable maintainer-specific
>>>>> portions of Makefiles
>>>>> configure:2492: result: no
>>>>> configure:2593: checking for bf537Stamp.cfg
>>>>> configure:2607: result: ../../../rtems/c/../make/custom/bf537Stamp.cfg
>>>>> configure:2899: creating ./config.status
>>>>> ## Running config.status. ##
>>>>> This file was extended by rtems-c config.status 4.9.99.0, which was
>>>>> CONFIG_FILES =
>>>>> CONFIG_HEADERS =
>>>>> CONFIG_LINKS =
>>>>> CONFIG_COMMANDS =
>>>>> $ ./config.status
>>>>> on xpcelslinux1
>>>>> config.status:690: creating Makefile
>>>>> ## Cache variables. ##
>>>>> ac_cv_build=i686-pc-linux-gnu
>>>>> ac_cv_env_build_alias_set=set
>>>>> ac_cv_env_build_alias_value=i686-pc-linux-gnu
>>>>> ac_cv_env_host_alias_set=set
>>>>> ac_cv_env_host_alias_value=bfin-rtems4.10
>>>>> ac_cv_env_target_alias_set=set
>>>>> ac_cv_env_target_alias_value=bfin-rtems4.10
>>>>> ac_cv_host=bfin-unknown-rtems4.10
>>>>> ac_cv_path_install='/usr/bin/install -c'
>>>>> ac_cv_path_mkdir=/bin/mkdir
>>>>> ac_cv_prog_AWK=mawk
>>>>> ac_cv_prog_MAKE=make
>>>>> ac_cv_prog_STRIP=bfin-rtems4.10-strip
>>>>> ac_cv_prog_make_make_set=yes
>>>>> ac_cv_target=bfin-unknown-rtems4.10
>>>>> ## Output variables. ##
>>>>> ACLOCAL='${SHELL} /home/els/rtems/rtems/missing --run aclocal-1.10'
>>>>> AMTAR='${SHELL} /home/els/rtems/rtems/missing --run tar'
>>>>> AUTOCONF='${SHELL} /home/els/rtems/rtems/missing --run autoconf'
>>>>> AUTOHEADER='${SHELL} /home/els/rtems/rtems/missing --run autoheader'
>>>>> AUTOMAKE='${SHELL} /home/els/rtems/rtems/missing --run automake-1.10'
>>>>> AWK='mawk'
>>>>> CYGPATH_W='echo'
>>>>> DEFS='-DPACKAGE_NAME=\"rtems-c\" -DPACKAGE_TARNAME=\"rtems-c\"
>>>>> -DPACKAGE_VERSION=\"4.9.99.0\" -DPACKAGE_STRING=\"rtems-c\
>>>>> 4.9.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\"'
>>>>> ECHO_C=''
>>>>> ECHO_N='-n'
>>>>> ECHO_T=''
>>>>> INSTALL_DATA='${INSTALL} -m 644'
>>>>> INSTALL_PROGRAM='${INSTALL}'
>>>>> INSTALL_SCRIPT='${INSTALL}'
>>>>> INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
>>>>> LIBOBJS=''
>>>>> LIBS=''
>>>>> LTLIBOBJS=''
>>>>> MAINT='#'
>>>>> MAINTAINER_MODE_FALSE=''
>>>>> MAINTAINER_MODE_TRUE='#'
>>>>> MAKE='make'
>>>>> MAKEINFO='${SHELL} /home/els/rtems/rtems/missing --run makeinfo'
>>>>> MKDIR_P='/bin/mkdir -p'
>>>>> PACKAGE='rtems-c'
>>>>> PACKAGE_BUGREPORT='http://www.rtems.org/bugzilla'
>>>>> PACKAGE_NAME='rtems-c'
>>>>> PACKAGE_STRING='rtems-c 4.9.99.0'
>>>>> PACKAGE_TARNAME='rtems-c'
>>>>> PACKAGE_VERSION='4.9.99.0'
>>>>> PATH_SEPARATOR=':'
>>>>> PROJECT_ROOT='../$(top_builddir)'
>>>>> PROJECT_TOPdir='../../$(top_builddir)'
>>>>> RTEMS_BSP_LIST=' bf537Stamp'
>>>>> RTEMS_CPU='bfin'
>>>>> RTEMS_TOPdir='..'
>>>>> SET_MAKE=''
>>>>> SHELL='/bin/sh'
>>>>> STRIP='bfin-rtems4.10-strip'
>>>>> VERSION='4.9.99.0'
>>>>> am__isrc=' -I$(srcdir)'
>>>>> am__leading_dot='.'
>>>>> am__tar='${AMTAR} chof - "$$tardir"'
>>>>> am__untar='${AMTAR} xf -'
>>>>> bindir='${exec_prefix}/bin'
>>>>> build='i686-pc-linux-gnu'
>>>>> build_alias='i686-pc-linux-gnu'
>>>>> build_cpu='i686'
>>>>> build_os='linux-gnu'
>>>>> build_vendor='pc'
>>>>> datadir='${datarootdir}'
>>>>> datarootdir='${prefix}/share'
>>>>> docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
>>>>> dvidir='${docdir}'
>>>>> exec_prefix='/opt/rtems-4.10/bfin-rtems4.10'
>>>>> host='bfin-unknown-rtems4.10'
>>>>> host_alias='bfin-rtems4.10'
>>>>> host_cpu='bfin'
>>>>> host_os='rtems4.10'
>>>>> host_vendor='unknown'
>>>>> htmldir='${docdir}'
>>>>> includedir='/opt/rtems-4.10/bfin-rtems4.10/include'
>>>>> infodir='${datarootdir}/info'
>>>>> install_sh='$(SHELL) /home/els/rtems/rtems/install-sh'
>>>>> libdir='${exec_prefix}/lib'
>>>>> libexecdir='${exec_prefix}/libexec'
>>>>> localedir='${datarootdir}/locale'
>>>>> localstatedir='${prefix}/var'
>>>>> mandir='${datarootdir}/man'
>>>>> mkdir_p='/bin/mkdir -p'
>>>>> oldincludedir='/usr/include'
>>>>> pdfdir='${docdir}'
>>>>> prefix='/opt/rtems-4.10'
>>>>> program_transform_name='s&^&bfin-rtems4.10-&'
>>>>> psdir='${docdir}'
>>>>> rtems_bsp_configure='../../../../rtems/c/src/configure
>>>>> '\''--prefix=/opt/rtems-4.10'\'' '\''--host=bfin-rtems4.10'\''
>>>>> '\''--build=i686-pc-linux-gnu'\'' '\''--target=bfin-rtems4.10'\''
>>>>> '\''--enable-tests=samples'\'' '\''--disable-posix'\''
>>>>> '\''--disable-itron'\'' '\''--with-target-subdir=bfin-rtems4.10'\''
>>>>> '\''--exec-prefix=/opt/rtems-4.10/bfin-rtems4.10'\''
>>>>> '\''--includedir=/opt/rtems-4.10/bfin-rtems4.10/include'\''
>>>>> '\''build_alias=i686-pc-linux-gnu'\''
>>>>> '\''host_alias=bfin-rtems4.10'\''
>>>>> '\''target_alias=bfin-rtems4.10'\''
>>>>> '\''--with-project-root=../../'\'' '\''--with-project-top=../../'\'''
>>>>> sbindir='${exec_prefix}/sbin'
>>>>> sharedstatedir='${prefix}/com'
>>>>> sysconfdir='${prefix}/etc'
>>>>> target='bfin-unknown-rtems4.10'
>>>>> target_alias='bfin-rtems4.10'
>>>>> target_cpu='bfin'
>>>>> target_os='rtems4.10'
>>>>> target_vendor='unknown'
>>>>> ## confdefs.h. ##
>>>>> #define PACKAGE_NAME "rtems-c"
>>>>> #define PACKAGE_TARNAME "rtems-c"
>>>>> #define PACKAGE_VERSION "4.9.99.0"
>>>>> #define PACKAGE_STRING "rtems-c 4.9.99.0"
>>>>> #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
>>>>> configure: exit 0
>>>>> Making all in make
>>>>> make[1]: Entering directory `/home/els/rtems/bf537Stamp/make'
>>>>> make[1]: Nothing to be done for `all'.
>>>>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/make'
>>>>> Making all in tools/build
>>>>> make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>>>>> make all-am
>>>>> make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
>>>>> gcc -DHAVE_CONFIG_H -I. -I../../../rtems/tools/build -g -O2 -MT
>>>>> cklength.o -MD -MP -MF .deps/cklength.Tpo -c -o cklength.o
>>>>> ../../../rtems/tools/build/cklength.c
>>>>> mv -f .deps/cklength.Tpo .deps/cklength.Po
>>>>> gcc -g -O2 -o cklength cklength.o
>>>>> eolstrip.o -MD -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o
>>>>> ../../../rtems/tools/build/eolstrip.c
>>>>> mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
>>>>> gcc -g -O2 -o eolstrip eolstrip.o
>>>>> packhex.o -MD -MP -MF .deps/packhex.Tpo -c -o packhex.o
>>>>> ../../../rtems/tools/build/packhex.c
>>>>> mv -f .deps/packhex.Tpo .deps/packhex.Po
>>>>> gcc -g -O2 -o packhex packhex.o
>>>>> unhex.o -MD -MP -MF .deps/unhex.Tpo -c -o unhex.o
>>>>> ../../../rtems/tools/build/unhex.c
>>>>> mv -f .deps/unhex.Tpo .deps/unhex.Po
>>>>> gcc -g -O2 -o unhex unhex.o
>>>>> rtems-bin2c.o -MD -MP -MF .deps/rtems-bin2c.Tpo -c -o rtems-bin2c.o
>>>>> ../../../rtems/tools/build/rtems-bin2c.c
>>>>> mv -f .deps/rtems-bin2c.Tpo .deps/rtems-bin2c.Po
>>>>> gcc -g -O2 -o rtems-bin2c rtems-bin2c.o
>>>>> binpatch.o -MD -MP -MF .deps/binpatch.Tpo -c -o binpatch.o
>>>>> ../../../rtems/tools/build/binpatch.c
>>>>> mv -f .deps/binpatch.Tpo .deps/binpatch.Po
>>>>> gcc -g -O2 -o binpatch binpatch.o
>>>>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>>>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
>>>>> Making all in tools/cpu
>>>>> make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>> Making all in generic
>>>>> `/home/els/rtems/bf537Stamp/tools/cpu/generic'
>>>>> make[2]: Nothing to be done for `all'.
>>>>> make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>> make[2]: Nothing to be done for `all-am'.
>>>>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
>>>>> Making all in testsuites/tools
>>>>> `/home/els/rtems/bf537Stamp/testsuites/tools'
>>>>> `/home/els/rtems/bf537Stamp/testsuites/tools/generic'
>>>>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>>>>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
>>>>> Making all in bfin-rtems4.10/c
>>>>> `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>>>> Making all in .
>>>>> Configuring RTEMS_BSP=bf537Stamp
>>>>> checking for gmake... no
>>>>> checking for make... make
>>>>> checking build system type... i686-pc-linux-gnu
>>>>> checking host system type... bfin-unknown-rtems4.10
>>>>> checking rtems target cpu... bfin
>>>>> checking for a BSD-compatible install... /usr/bin/install -c
>>>>> checking whether build environment is sane... yes
>>>>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>>>>> checking for gawk... no
>>>>> checking for mawk... mawk
>>>>> checking whether make sets $(MAKE)... yes
>>>>> checking for bfin-rtems4.10-strip... bfin-rtems4.10-strip
>>>>> checking whether to enable maintainer-specific portions of
>>>>> Makefiles... no
>>>>> checking for RTEMS_BSP... bf537Stamp
>>>>> checking for
>>>>> ../../../../rtems/c/src/../../bspkit/bfin/*/cfg/bf537Stamp.cfg... no
>>>>> checking for
>>>>> ../../../../rtems/c/src/../../make/custom/bf537Stamp.cfg... yes
>>>>> checking whether BSP supports networking... yes
>>>>> checking whether CPU supports libposix... disabled
>>>>> configure: setting up make/custom
>>>>> checking for
>>>>> checking for
>>>>> configure: creating make/bf537Stamp.cache
>>>>> make[3]: Entering directory
>>>>> `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp'
>>>>> make[3]: Leaving directory
>>>>> checking for RTEMS_CPU_MODEL... bf537
>>>>> checking for RTEMS_BSP_FAMILY... (cached) bf537Stamp
>>>>> checking for CPU_CFLAGS... (cached)
>>>>> checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
>>>>> checking for style of include used by make... GNU
>>>>> checking for bfin-rtems4.10-gcc... bfin-rtems4.10-gcc
>>>>> checking for bfin-rtems4.10-gcc... (cached) bfin-rtems4.10-gcc
>>>>> checking for C compiler default output file name...
>>>>> configure: error: in
>>>>> `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp':
>>>>> configure: error: C compiler cannot create executables
>>>>> See `config.log' for more details.
>>>>> make[2]: *** [bf537Stamp] Error 1
>>>>> make[2]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>>>> make[1]: *** [all-recursive] Error 1
>>>>> make[1]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
>>>>> make: *** [all-recursive] Error 1
