sparc-rtems-gdb error
ORMANCEY Nicolas nicolas.ormancey at sogeti.com
Thu Jun 25 14:14:46 UTC 2009
Thanks Sebastian
My host platform is Linux
And I use the Gaisler RCC-1.1.0 package
This shared lib is nowhere installed on my host.
So where find this Shared lib and where install it.
Thanks
-----Message d'origine-----
De : Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Envoyé : jeudi 25 juin 2009 16:04
À : ORMANCEY Nicolas
Cc : rtems-users at rtems.org
Objet : Re: sparc-rtems-gdb error
ORMANCEY Nicolas wrote:
> Hi every body,
> I'm working on 4.8.1 RTEMS version
> I'm trying to use sparc-rtems-gdb.
> But when I try to launch it I've got the message
> 	Error while lauding shared libraries: libreadline.so.4: cannot open
> shared object file: No such file or directory
You need to obtain the readline shared library from somewhere.  It may help
to
mention the OS you use and how you installed the RTEMS tools.
> After checking the tools tree I found nothing!!
> I really need to debug my job, how can I use gdb and which version should
I
> use?
> rtems-users mailing list
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
