sparc-rtems-gdb error
Sebastian Huber
Thu Jun 25 14:04:15 UTC 2009
ORMANCEY Nicolas wrote:
> Hi every body,
> I'm working on 4.8.1 RTEMS version
> I'm trying to use sparc-rtems-gdb.
> But when I try to launch it I've got the message
> Error while lauding shared libraries: libreadline.so.4: cannot open
> shared object file: No such file or directory
You need to obtain the readline shared library from somewhere. It may help to
mention the OS you use and how you installed the RTEMS tools.
> After checking the tools tree I found nothing!!
> I really need to debug my job, how can I use gdb and which version should I
> use?
> rtems-users mailing list
> rtems-users at rtems.org
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
