Debian-host build error...
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Tue Jun 30 15:48:48 UTC 2009
Ed Sutter wrote:
> Just to keep the email in sync...
> Prior to getting this message, I restarted with redhat/el5, and as reported,
> it looks good!
For the record: These are the CentOS 5-built rpms, I was referring to.
This OS is antiquated enough, to be compatible to other "ultra
conservative" OSes, such as Debian.
On Ubuntu, the situation likely is different. They typically are "on
par" or "one small step behind" with the versions being used by Fedora.
There, CentOS5 rpms also will likely work, but chances are some versions
of Fedora will also do.
Ralf
