yum update for powerpc-gdb (fedora8)
Gene Smith
gds at chartertn.net
Fri Mar 13 17:54:35 UTC 2009
I was under the impression that no further updates would occur for f8
for rtems tools. Today, on reboot after running about 4 months, I saw an
update message for upgrading powerpc-gdb but I only have ARM installed.
The details indicated it was not actually powerpc specific so I allowed
the upgrade.
Here is what I had before the upgrade:
rpm -qa | grep rtems.*4\.9.*gdb
rtems-4.9-arm-rtems4.9-gdb-6.8-4.fc8
rtems-4.9-gdb-common-6.8-4.fc8
After:
rtems-4.9-gdb-common-6.8-6.el5
The versions don't match and the common one is for "el5" not "fc8" it
seems. Is this OK? gdb still seems to run.
-gene
