yum update for powerpc-gdb (fedora8)
Ralf Corsepius
ralf.corsepius at rtems.org
Sat Mar 14 03:20:39 UTC 2009
Gene Smith wrote:
> I was under the impression that no further updates would occur for f8
> for rtems tools.
Correct. We discontinued building the toolchains for Fedora 8 and
redirected the Fedora 8 repos to those of CentOS 5, as legacy to users
who for some reasons can't upgrade to a newer Fedora.
Side-effects of this:
* Fedora 8 users, who have the original fc8-compiled toolchains
installed, will see their rtems packages gradually be replaced with
CentOS5 compiled ones, in cases of toolchain updates or when
reinstalling rtems toolchain packages.
* Fedora 8 users, who freshly install the rtems toolchains, will receive
CentOS5 compiled packages.
> Today, on reboot after running about 4 months, I saw an
> update message for upgrading powerpc-gdb but I only have ARM installed.
> The details indicated it was not actually powerpc specific so I allowed
> the upgrade.
> Here is what I had before the upgrade:
> rpm -qa | grep rtems.*4\.9.*gdb
> rtems-4.9-arm-rtems4.9-gdb-6.8-4.fc8
> rtems-4.9-gdb-common-6.8-4.fc8
> After:
> rtems-4.9-gdb-common-6.8-6.el5
> The versions don't match and the common one is for "el5" not "fc8" it
> seems. Is this OK?
Yes, this is OK.
What you are observing is a side effect of the powerpc-rtems4.9-gdb
toolchain having received a bugfix update. You received the latest
"*-common" package all gdbs share, from CentOS 5 (dist-tag .el5).
Ralf
