Raw FRAM device (via SPI) - libi2c issue?
Robert S. Grimes
rsg at alum.mit.edu
Fri Mar 13 22:49:44 UTC 2009
Okay, more detail here. I added some debug output
in my fram driver code, and found where the five
bytes are lost. Here is the snippet from the fram
write routine:
* send "page program" command and address
#ifdef DEBUG_FRAM
printk(" Write %d bytes to %u\n", cnt, off);
#endif
if (rc == RTEMS_SUCCESSFUL) {
cmdbuf[0] = FRAM_CMD_WRITE;
cmdbuf[1] = (off >> 8) & 0xff;
cmdbuf[2] = (off >> 0) & 0xff;
ret_cnt =
rtems_libi2c_write_bytes(minor,cmdbuf,3);
if (ret_cnt < 0) {
rc = -ret_cnt;
* send write data
#ifdef DEBUG_FRAM
printk(" Calling
rtems_libi2c_write_bytes(%d,0x%p,%d)\n", minor,
buf, cnt);
#endif
ret_cnt =
rtems_libi2c_write_bytes(minor,buf,cnt);
#ifdef DEBUG_FRAM
printk(" Returned %d\n", ret_cnt);
#endif
if (ret_cnt < 0) {
rc = -ret_cnt;
} else {
bytes_sent = cnt;
For those who are unfamiliar with fram, the first
call to rtems_libi2c_write_bytes sends a write
opcode and a two-byte offset, while the second sends
the data to be written. Anyway, here is the output:
Okay, let's try to write...
fram write
Write 32 bytes to 0
Calling
rtems_libi2c_write_bytes(83968,0x57F6B4,32)
Returned 27
write returned 32
fram write
Write 12 bytes to 32
Calling
rtems_libi2c_write_bytes(83968,0x57F6B4,12)
Returned 12
write returned 12
And now, read...
fram read
Read 64 bytes from 0 - rc: 0
read returned 49
30 31 32 33 34 35 36 37 38 39 61 62 63 64 65 66
|0123456789abcdef|
41 39 38 37 36 35 34 33 32 31 30 48 65 6c 6c 6f
|A9876543210Hello|
64 2e 00 00 00 00 00 00 00 00 00 00 00 00 00 00
|d...............|
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
So why does rtems_libi2c_write_bytes return only 27
when I send it 32, and why does it trash the five
bytes after the first 16? Seems to be a libi2c
issue?
Thanks,
-Bob
---- Original message ----
Date: Fri, 13 Mar 2009 18:29:22 -0400 (EDT)
Subject: Raw FRAM device (via SPI)
To: RTEMS <rtems-users at rtems.org>
I have a 32 kilobyte FRAM device on my board that
I would like to use. It is interfaced to the
(Virtex) processor via SPI. I've been using the
SPI driver for A/D and D/A converters, as well as
for an SD card, pretty much with no trouble. But
now, the FRAM is a bit different...
Because of the small size and my intended usage
(simple byte-stream logging), I had intended to
use it as a simple chunk of memory - in other
words, no file system. Here is my test code:
fd = open("/dev/spi2.fram", O_RDWR);
printf("open returned %d\n", fd);
if (fd >= 0) {
printf("\n*** Simple FRAM Test *** \n\n");
printf("First, let's try to read pre-existing
contents\n");
char buffer[64];
int num0 = read(fd, buffer, 64);
printf("read returned %d\n", num0);
rtems_print_buffer((unsigned char*)buffer,
64);
printf("\nOkay, let's try to write...\n");
memset(buffer, 0, 64);
strcpy(buffer,
"0123456789abcdefFEDCBA9876543210");
lseek(fd, 0, SEEK_SET);
int num1 = write(fd, buffer, strlen(buffer));
printf("write returned %d\n", num1);
strcpy(buffer, "Hello world.");
int num2 = write(fd, buffer, strlen(buffer));
printf("write returned %d\n", num2);
char rbuffer[64];
memset(rbuffer, 0, 64);
printf("And now, read...\n");
int num3 = read(fd, rbuffer, 64);
printf("read returned %d\n", num3);
rtems_print_buffer((unsigned char*)rbuffer,
64);
close(fd);
This is the results the first time it is run:
Trying to open fram...
open returned 4
First, let's try to read pre-existing contents
read returned 49
00 aa 55 55 aa aa 55 55 aa aa 55 55 aa aa 55 55
|..UU..UU..UU..UU|
write returned 32
write returned 12
And now, read...
read returned 49
|0123456789abcdef|
|A9876543210Hello|
|d...............|
Here is the second run, after powering off:
open returned 4
read returned 49
|0123456789abcdef|
|A9876543210Hello|
|d...............|
|..UU..UU..UU..UU|
write returned 32
write returned 12
And now, read...
read returned 49
|0123456789abcdef|
|A9876543210Hello|
|d...............|
Notice the problem(s)? It seems as though after
writing 16 bytes, the next five are discarded.
This seems to continue going forward. Any ideas?
Thanks,
-Bob
Robert S. Grimes
RSG Associates
Embedded Systems and Software Development
for Military, Aerospace, Industry - and beyond!
617.697.8579
www.rsgassoc.com
>________________
>_______________________________________________
>rtems-users mailing list >rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
Robert S. Grimes
RSG Associates
617.697.8579
www.rsgassoc.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20090313/68f453d0/attachment.html>
