Raw FRAM device (via SPI)
Robert S. Grimes
rsg at alum.mit.edu
Fri Mar 13 22:29:22 UTC 2009
I have a 32 kilobyte FRAM device on my board that I
would like to use. It is interfaced to the (Virtex)
processor via SPI. I've been using the SPI driver
for A/D and D/A converters, as well as for an SD
card, pretty much with no trouble. But now, the
FRAM is a bit different...
Because of the small size and my intended usage
(simple byte-stream logging), I had intended to use
it as a simple chunk of memory - in other words, no
file system. Here is my test code:
fd = open("/dev/spi2.fram", O_RDWR);
printf("open returned %d\n", fd);
if (fd >= 0) {
printf("\n*** Simple FRAM Test *** \n\n");
printf("First, let's try to read pre-existing
contents\n");
char buffer[64];
int num0 = read(fd, buffer, 64);
printf("read returned %d\n", num0);
rtems_print_buffer((unsigned char*)buffer, 64);
printf("\nOkay, let's try to write...\n");
memset(buffer, 0, 64);
strcpy(buffer,
"0123456789abcdefFEDCBA9876543210");
lseek(fd, 0, SEEK_SET);
int num1 = write(fd, buffer, strlen(buffer));
printf("write returned %d\n", num1);
strcpy(buffer, "Hello world.");
int num2 = write(fd, buffer, strlen(buffer));
printf("write returned %d\n", num2);
char rbuffer[64];
memset(rbuffer, 0, 64);
printf("And now, read...\n");
int num3 = read(fd, rbuffer, 64);
printf("read returned %d\n", num3);
rtems_print_buffer((unsigned char*)rbuffer, 64);
close(fd);
This is the results the first time it is run:
Trying to open fram...
open returned 4
First, let's try to read pre-existing contents
read returned 49
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 aa 55 55 aa aa 55 55 aa aa 55 55 aa aa 55 55
|..UU..UU..UU..UU|
write returned 32
write returned 12
And now, read...
read returned 49
30 31 32 33 34 35 36 37 38 39 61 62 63 64 65 66
|0123456789abcdef|
41 39 38 37 36 35 34 33 32 31 30 48 65 6c 6c 6f
|A9876543210Hello|
64 2e 00 00 00 00 00 00 00 00 00 00 00 00 00 00
|d...............|
Here is the second run, after powering off:
open returned 4
read returned 49
|0123456789abcdef|
|A9876543210Hello|
|d...............|
|..UU..UU..UU..UU|
write returned 32
write returned 12
And now, read...
read returned 49
|0123456789abcdef|
|A9876543210Hello|
|d...............|
Notice the problem(s)? It seems as though after
writing 16 bytes, the next five are discarded. This
seems to continue going forward. Any ideas?
Thanks,
-Bob
Robert S. Grimes
RSG Associates
Embedded Systems and Software Development
for Military, Aerospace, Industry - and beyond!
617.697.8579
www.rsgassoc.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20090313/fc17f5ea/attachment.html>
