Console buffer size
Michael Hamel
mhamel at adi.co.nz
Wed Mar 18 22:59:11 UTC 2009
My BSP uses the standard 16550 driver found in ../powerpc/shared/
console, which seems to hook in to the termios code in cpukit/
libcsupport/src. After some searching it looks as though the code is
interrupt-driven, but is limited to a rather small buffer size which
is hard-coded in that file as rtems_termios_raw_output_size. The baud
rate is also hard coded as 9600 in console_first_open() in console.c.
The limitations of my debugger mean that I use console debugging
rather a lot and as I'm not at all short of RAM I would like to use a
much larger buffer and higher baud rates so that generating log
information doesn't suspend my tasks while they wait for the UART. I'm
sure that editing the shared termios.c and console.c isn't the right
way to do this(!)
Is there some appropriate way of configuring the console buffer size
(and baud rate) in bsp.h, or some way of calling the termios code to
get the rate changed and buffer resized at startup? I can't find any
documentation or examples that seem to cover this...
Thanks for any assistance,
"Quick! Burn the books. Tear up those revolting postcards. Chase those
women out of my room. Take all those "For Sale" signs off the
furniture and help me get the floor back under this carpet."
Michael Hamel
ADInstruments Ltd, Dunedin, NZ
