Console buffer size
Chris Johns
chrisj at rtems.org
Wed Mar 18 23:29:33 UTC 2009
Michael Hamel wrote:
> My BSP uses the standard 16550 driver found in ../powerpc/shared/
> console, which seems to hook in to the termios code in cpukit/
> libcsupport/src. After some searching it looks as though the code is
> interrupt-driven, but is limited to a rather small buffer size which
> is hard-coded in that file as rtems_termios_raw_output_size. The baud
> rate is also hard coded as 9600 in console_first_open() in console.c.
> The limitations of my debugger mean that I use console debugging
> rather a lot and as I'm not at all short of RAM I would like to use a
> much larger buffer and higher baud rates so that generating log
> information doesn't suspend my tasks while they wait for the UART. I'm
> sure that editing the shared termios.c and console.c isn't the right
> way to do this(!)
> Is there some appropriate way of configuring the console buffer size
> (and baud rate) in bsp.h, or some way of calling the termios code to
> get the rate changed and buffer resized at startup? I can't find any
> documentation or examples that seem to cover this...
Yes nothing I see covers the set up call. It is 'rtems_termios_bufsize' and
defined in libio_.h in cpukit/libcsupport.
You need to make this call before the console is opened. You cannot change the
settings once the driver has initialised.
Regards
