RTEMS device driver ioctl argument?
mike antispam21 at verizon.net
Thu Mar 26 02:04:37 UTC 2009
Hi all,
When we call RTEMS device driver function ioctl(fd, a, b), it gets to
the driver ioctl entry point with 3 arguments: major, minor, arg. With
'arg' a pointer to rtems_libio_ioctl_args_t struct:
typedef struct {
  rtems_libio_t *iop;
  uint32_t command;
  void  *buffer;
  uint32_t ioctl_return;
} rtems_libio_ioctl_args_t;
with 'a' in 'command', 'b' in '*buffer'.
The questions are:
- what's 'iop'?
- is the error code supposed to be returned in 'ioctl_return'? If yes,
how does the caller retrieve it?
Thanks.
-mike-
