Nios2 problems when building tests
Fri Mar 27 13:41:41 UTC 2009
Roger Dahlkvist wrote:
> Instead of using the simulator I just created a simple system with the same contents as the nios2_iss bsp, except for an external sdram since the FPGA I'm currently using can't have enough onchip memory. I replaced linkcmd and made the required changes to bsp.h
> So far it runs just perfectly on hardware. Currently it's only a single task counting numbers though.
> I just had a brief look in the debugger and as far as I can tell, it looks ok.
I am thrilled this works.
Is this with my linkcmds change that moves the starting stack?
--joel
> //Roger
> Joel Sherrill wrote:
>> Morten Kristiansen wrote:
>>> As a shortcut, could you send me the binary image you have, please?
>> Grrr.. now it isn't linking for me. Maybe I didn't get as far as I
>> remembered
>> or I have deleted the RTEMS tree. It looks close so i will work on it.
>> Maybe in the morning you will have something if my build finishes.
> My changes that should be committed now are.  Attached
> is a patch for the Makefile's so we don't use a file list and
> work with the old ar command.
> The starting stack is CLEARLY at the end of RAM in the
> start/start.S and startup/linkcmds.  This is used as
> work area so getting clobbered early.
> Attached in a private email is my hello if you want to look at
> it but we know the stack is broken.
>> --joel
>>> /MK
>>> 2009/3/25 Roger Dahlkvist <ruppe at kth.se>:
>>>> Hi,
>>>> Yes, I defenately think the errors are memory related. I'll look at the hints you gave.
>>>> When I for example run hello.exe in the Altera NiosII ISS I get the following errors before the program terminates.
>>>> Error! : Failed memory access in component cpu_0 - Reading data 0x0 from uninitialized memory (addr = 0x1f33c)
>>>> Error! : Simulation failed in component cpu_0 at instruction 33372 (PC=0x8eb8 instr=0x2c000017).
>>>> //Roger
>>>>> Thanks, any help is greatly appreciated.
>>>>> The status for me right now is that I have switched to newlib-1.17.0.  I also changed both cpukit/wrapup/Makefile.am and c/src/wrapup/Makefile.am, as suggested.
>>>>> That fixed most errors, now that both librtemscpu.a and librtemsbsp.a are added correctly.
>>>> Then you are probably close to in sync with what I have
>>>> on my laptop at home.
>>>>> I've tried myself to solve the remaining issues, by including /shared/bsppretaskinghook.c to libbsp.a, and define WorkAreaBase in linkcmds.
>>>>> However the resulting tests fail in the simulator, so that might not have been the right way to go, or there are other things to consider aswell.
>>>> How do the tests fail?
>>>> Usually at this point it is memory layout.
>>>> All BSPs now use the same framework for BSP initialization
>>>> and most use exactly the same mechanism for dividing memory
>>>> between the RTEMS Workspace and C program heap.
>>>> Can you get debug IO via printk at this point on the simulator?
>>>> If so, make printk work and turn on debugging in libbsp/shared/bootcard.c.
>>>> If not, or if it is just as easy, trace through bootcard.c in the debugger
>>>> and see if things look ok.
>>>> Also (very common), the starting stack (the one the BSP start code
>>>> runs on) may NOT be properly accounted for in the linkcmds and
>>>> your work memory (workspace and C program heap) may overlap it.
>>>> Then the init is clobbering the stack out from underneath you.
>>>> _-joel
>>>>> Looking forward to your inputs.
>>>>> //Roger
>>>>> ________________________________________
>>>>> Från: millibit at gmail.com [millibit at gmail.com] för Morten Kristiansen [millibit+rtems at gmail.com]
>>>>> Skickat: den 24 mars 2009 09:30
>>>>> Till: Joel Sherrill
>>>>> Kopia: Roger Dahlkvist; rtems-users at rtems.com
>>>>> Ämne: Re: Nios2 problems when building tests
>>>>> 2009/3/20 Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>> My full NIOS patches are at home.  Morten can help you
>>>>>> get things going.
>>>>> I should think so. I'll take a look at it this evening.
>>>>>> The biggest issue you are facing is that the NIOS II binutils
>>>>>> version Altera uses is TOO old for the feature used in cpukit/wrapup.
>>>>> I fetched the relevant versions into Subversion and tried merging. It
>>>>> wasn't straightforward, but as a quick solution I can create a patch
>>>>> that allows it to read options from a file.
>>>>> /MK
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>   Support Available             (256) 722-9985
>> rtems-users mailing list
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
