Microseconds per tick
Fri Mar 27 08:22:18 UTC 2009
Leonard Bise wrote:
> Hi all,
> I'm quite new to RTEMS and I'm not very experienced so I hope you can
> give me an hand!
> We are working with a board using a LEON2 Sparc processor running at
> 80Mhz, I figured that the microseconds per tick value would be 0.0125
> (is this correct?).
> Shall I simply configure my application with this define ? #define
> CONFIGURE_MICROSECONDS_PER_TICK 0.0125 ?
No. The question is how many micro seconds shall elapse per system tick?
Suppose you want 10000 micro seconds per tick, then you define
#define CONFIGURE_MICROSECONDS_PER_TICK 10000
It is the duty of the kernel and BSP to make the appropriate settings for each
configuration option.
> I hope you can help, thanks in advance.
> Léonard.
> ps: By the way I posted once using the wrong mail address and it said it
> was awaiting approval from the moderators, please delete this one. This
> is the correct address.
> rtems-users mailing list
> rtems-users at rtems.com
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
