RES: ERC32 clock counter incorrect
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Fri Mar 6 17:30:45 UTC 2009
Hi Manuel,
Note that -1 is added in ERC32_MEC.Real_Time_Clock_Scalar.
#define Clock_driver_support_initialize_hardware() \
do { \
/* approximately 1 us per countdown */ \
ERC32_MEC.Real_Time_Clock_Scalar = CLOCK_SPEED - 1; \
ERC32_MEC.Real_Time_Clock_Counter = \
BSP_Configuration.microseconds_per_tick; \
ERC32_MEC_Set_Real_Time_Clock_Timer_Control( \
ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING | \
ERC32_MEC_TIMER_COUNTER_LOAD_SCALER | \
ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER \
ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO \
} while (0)
I don't think it is a bug. How do you do the verification?
Att.
Wendell.
________________________________
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Manuel
Enviada em: sexta-feira, 6 de março de 2009 12:30
Para: rtems-users at rtems.com
Assunto: ERC32 clock counter incorrect
Hi
We have discovered a bug in the ERC32 clock driver (at least for the RTEMS 4.8.0 version).
Currently, the RTC counter is being initialized with (on the ckinit.c file)
This way it is adding an extra microsecond for each clock tick.
The correct set value should be
BSP_Configuration.microseconds_per_tick - 1;
the other SPARC BSPs (leon2 and leon3) clocks seam ok :)
Kind regards
Manuel Coutinho
URL: <http://lists.rtems.org/pipermail/users/attachments/20090306/d0f7456a/attachment-0001.html>
