ERC32 clock counter incorrect
Manuel Coutinho
manuel.coutinho at edisoft.pt
Fri Mar 6 17:47:15 UTC 2009
Hi
The Scalar value is correct, you should subtract one. But on the clock
counter as well (counts from 0 to microseconds per tick minus one).
Ive tested using the GPT timer on ERC32 and it was giving a microsecond in
each clock tick.
Using the -1 patch, it was ok.
Look at the same code of the leon2 and leon3 for example, they also subtract
one unit.
Kind regards
Manuel Coutinho
_____
From: Wendell Pereira da Silva [mailto:wendell.silva at compsisnet.com.br]
Sent: Friday, March 06, 2009 5:31 PM
To: Manuel; rtems-users at rtems.com
Subject: RES: ERC32 clock counter incorrect
Hi Manuel,
Note that -1 is added in ERC32_MEC.Real_Time_Clock_Scalar.
#define Clock_driver_support_initialize_hardware() \
do { \
/* approximately 1 us per countdown */ \
ERC32_MEC.Real_Time_Clock_Scalar = CLOCK_SPEED - 1; \
ERC32_MEC.Real_Time_Clock_Counter = \
BSP_Configuration.microseconds_per_tick; \
ERC32_MEC_Set_Real_Time_Clock_Timer_Control( \
ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING | \
ERC32_MEC_TIMER_COUNTER_LOAD_SCALER | \
ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER \
ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO \
} while (0)
I dont think it is a bug. How do you do the verification?
Att.
Wendell.
_____
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em
nome de Manuel
Enviada em: sexta-feira, 6 de março de 2009 12:30
Para: rtems-users at rtems.com
Assunto: ERC32 clock counter incorrect
Hi
We have discovered a bug in the ERC32 clock driver (at least for the RTEMS
4.8.0 version).
Currently, the RTC counter is being initialized with (on the ckinit.c file)
This way it is adding an extra microsecond for each clock tick.
The correct set value should be
BSP_Configuration.microseconds_per_tick - 1;
the other SPARC BSPs (leon2 and leon3) clocks seam ok :)
Kind regards
Manuel Coutinho
URL: <http://lists.rtems.org/pipermail/users/attachments/20090306/a33b3556/attachment-0001.html>
