test build of 4.9 started
Kate Feng
feng1 at bnl.gov
Mon Mar 9 18:49:36 UTC 2009
Please never mind. I just realized that RTEMS main() is
indeed defined as
int main(int argc, char **argv, char **environp)
instead of the usual
int main( int, char **);
Kate
Kate Feng wrote:
> Joel Sherrill wrote:
>> Hi,
>> I just started a test build of the 4.9 branch.
>> If all goes well, I will cut 4.9.2 once it is
>> finished.
>> pr1385 will be closed. I am building with
>> the latest patch.
>> If you have an outstanding issue, yell now.
> In cpukit/libmisc/dummy/dummy.c, should
> "int main( int, char **, char **); "
> be corrected as
> "int main( int, char **);"
> Is there a conflict ?
> Kate
> rtems-users mailing list
> rtems-users at rtems.com
