test build of 4.9 started
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Mar 9 19:02:20 UTC 2009
Kate Feng wrote:
> Please never mind. I just realized that RTEMS main() is
> indeed defined as
> int main(int argc, char **argv, char **environp)
> instead of the usual
> int main( int, char **);
It would be better to match C99 though if we can
get a definitive answer.
--joel
> Kate
> Kate Feng wrote:
>> Joel Sherrill wrote:
>>> Hi,
>>> I just started a test build of the 4.9 branch.
>>> If all goes well, I will cut 4.9.2 once it is
>>> finished.
>>> pr1385 will be closed. I am building with
>>> the latest patch.
>>> If you have an outstanding issue, yell now.
>> In cpukit/libmisc/dummy/dummy.c, should
>> "int main( int, char **, char **); "
>> be corrected as
>> "int main( int, char **);"
>> Is there a conflict ?
>> Kate
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
