RTEMS 4.10 on Fedora 10 Virtual Machine
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 17 16:23:24 UTC 2009
I found a python backtrace from the bittorrent, patched
it and Jeff confirms it is working again from inside our
LAN.
Bittorrent is often blocked at firewalls. I will be testing
from my house tonight.
I would appreciate a confirmation that is appears OK to
someone, somewhere outside OAR. :)
--joel
Joel Sherrill wrote:
> Jeffrey Engel wrote:
>>> Hi
>>> We have just created a virtual machine of Fedora 10 with
>>> the RTEMS 4.10 development environment preinstalled.
>>> Further information is available here...
>>> http://www.rtems.org/wiki/index.php/Virtual_Machines_for_RTEMS_Development
>>> Use it as you see fit, and please report any problems.
>>> Thanks
>>> Jeff
>> I'm having some difficulty downloading the torrent. Can someone verify whether its working for them?
>> The issue may very well be on my end. . .
> Can you give some hints on what the problem is?
>> Jeff Engel
>> Happiness is - positive intake manifold pressure.
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
