i got error with runing ticker.exe from Quick Start
Daron Chabot
daron.chabot at gmail.com
Fri Mar 20 17:16:12 UTC 2009
>From this bug report (
https://bugs.launchpad.net/ubuntu/+source/expat/+bug/218963 ), the fix
seems to a symlink, as Joel has suggested:
sudo ln -s /usr/lib/libexpat.so.1 /usr/lib/libexpat.so.0
-- dc
On Fri, Mar 20, 2009 at 11:04 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Ralf Corsepius wrote:
>> Joel Sherrill wrote:
>>> Konstantin Volkov wrote:
>>>> directory) i got the error sparc-rtems4.10-gdb:error while loading
>>>> shared libraries: libexpat.so.0:
>>>> cannot open shared object file: No such file or directory
>> libexpat.so.0? Which distribution's rpm did you use to convert?
>>>> why it can not find the file from ticker directory (there is
>>>> ticket.exe in ticket directory
>>>> why it answered what sparc-rtems4.10-gdb is not exist comand?
>>> Since you used alien to convert the RPMs to Debian, you didn't
>>> get the dependencies processed magically for you. I don't know
>>> where that library comes from on Ubuntu.
>> According to http://www.debian.org/distrib/packages, Debian ships
>> libexpat.so.1 in its libexpat1.
>> => The rpm based distro you used is likely incompatible to Debian/Ubuntu.
>> => The package you would have to install is likely called libexpat1
> I saw some Ubuntu traffic that other packages were having
> trouble even building packages because of this library
> and were recommending making a symlink as a fix.
> Better if it can be installed.
>> Ralf
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.com
