i got error with runing ticker.exe from Quick Start
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 20 17:04:58 UTC 2009
Ralf Corsepius wrote:
> Joel Sherrill wrote:
>> Konstantin Volkov wrote:
>>> directory) i got the error sparc-rtems4.10-gdb:error while loading
>>> shared libraries: libexpat.so.0:
>>> cannot open shared object file: No such file or directory
> libexpat.so.0? Which distribution's rpm did you use to convert?
>>> why it can not find the file from ticker directory (there is
>>> ticket.exe in ticket directory
>>> why it answered what sparc-rtems4.10-gdb is not exist comand?
>> Since you used alien to convert the RPMs to Debian, you didn't
>> get the dependencies processed magically for you. I don't know
>> where that library comes from on Ubuntu.
> According to http://www.debian.org/distrib/packages, Debian ships
> libexpat.so.1 in its libexpat1.
> => The rpm based distro you used is likely incompatible to Debian/Ubuntu.
> => The package you would have to install is likely called libexpat1
I saw some Ubuntu traffic that other packages were having
trouble even building packages because of this library
and were recommending making a symlink as a fix.
Better if it can be installed.
> Ralf
