Nios2 problems when building tests
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 20 18:30:08 UTC 2009
Roger Dahlqvist wrote:
> Hello,
> I'm currently trying to buils rtems for Nios2. I'm using the CVS head as of
> March 16, and Newlib-1.16.0. As a starting point I wish to use the
> nios2_iss bsp.
> Both Newlib and RTEMS seem to build without any problems, however when the
> tests are built for the bsp, I get some errors.
> As I see it, some libraries are for some reason not included then linking.
> I've also noticed that librtemsbsp.a is empty, and that doesn't seem right.
> My guess is that there is something I've missed in my wrapper script for
> the Altera tools and/or there might be something wrong with the bsp
> configuration,
> Has anyone successfully built the tests for the nios2_iss bsp? ("hello" for
> example).
I am cc'ing Morten Kristiansen. We did manage to get things
linking recently. I just posted a patch for newlib 1.17.0 for
the NIOS to the newlib mailing list. You definitely want to
use 1.17.0 with the latest patches.
My full NIOS patches are at home. Morten can help you
get things going.
The biggest issue you are facing is that the NIOS II binutils
version Altera uses is TOO old for the feature used in cpukit/wrapup.
Reverse this patch:
cvs diff -u -r 1.61 -r 1.62 cpukit/wrapup/Makefile.am
The librtemscpu.a is empty because of the old binutils. :)
--joel
> Any help or pointers are very much appreciated.
> Thanks
> /Roger
> * My current gcc wrapper for nios2-rtems-gcc, used for building newlib and
> rtems
> #!/bin/sh
> /opt/altera8.1/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/nios2-elf-gcc
> -nostdinc -isystem
> "/home/roger/Skrivbord/workdir/install/nios2-rtems/include" -isystem
> "/opt/altera8.1/nios2eds/bin/nios2-gnutools/H-i686-pc-linux-gnu/lib/gcc/nios2-elf/3.4.6/include"
> -B "/home/roger/Skrivbord/workdir/install/nios2-rtems/lib/" -msys-lib=c
> -msys-crt0="/home/roger/Skrivbord/workdir/install/nios2-rtems/lib/crt0.o"
> -DSYSTEM_BUS_WIDTH=32 -D__rtems__ -D__USE_INIT_FINI__ "$@"
> * This is part of the error message
> nios2-rtems-gcc -B../../../../../lib/ -B../../../../../nios2_iss/lib/
> -specs bsp_specs -qrtems -mno-hw-mul -mno-hw-div -O0 -g -mno-hw-mul
> -mno-hw-div -o hello.exe init.o
> ../../../../../nios2_iss/lib/no-barrier.rel
> ../../../../../nios2_iss/lib/no-dpmem.rel
> ../../../../../nios2_iss/lib/no-event.rel
> ../../../../../nios2_iss/lib/no-msg.rel
> ../../../../../nios2_iss/lib/no-mp.rel
> ../../../../../nios2_iss/lib/no-part.rel
> ../../../../../nios2_iss/lib/no-region.rel
> ../../../../../nios2_iss/lib/no-signal.rel
> ../../../../../nios2_iss/lib/no-timer.rel
> ../../../../../nios2_iss/lib/no-rtmon.rel
> ../../../../../nios2_iss/lib/no-ext.rel
> ../../../../../nios2_iss/lib/start.o(.text+0xac): In function
> `dcache_init_loop':
> : undefined reference to `boot_card'
> ../../../../../nios2_iss/lib/start.o(.text+0xb4): In function `brto_ev':
> : undefined reference to `_exception_vector'
> ../../../../../nios2_iss/lib/start.o(.text+0xb8): In function `brto_ev':
> ../../../../../nios2_iss/lib/start.o(.irq+0x0): undefined reference to
> `_exception_vector'
> ../../../../../nios2_iss/lib/start.o(.irq+0x4): undefined reference to
> `_exception_vector'
> init.o(.data+0x1c): In function `Init':
> /home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:32:
> undefined reference to `console_initialize'
> init.o(.data+0x20):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:33:
> undefined reference to `console_open'
> init.o(.data+0x24):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:33:
> undefined reference to `console_close'
> init.o(.data+0x28):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:33:
> undefined reference to `console_read'
> init.o(.data+0x2c):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:34:
> undefined reference to `console_write'
> init.o(.data+0x30):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:34:
> undefined reference to `console_control'
> init.o(.data+0x34):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:34:
> undefined reference to `newlib_create_hook'
> init.o(.data+0x40): undefined reference to `newlib_delete_hook'
> init.o(.data+0xcc): undefined reference to `_CPU_Thread_Idle_body'
> init.o(.sdata+0x0): In function `Init':
> /home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:31:
> undefined reference to `rtems_libio_init'
> init.o(.sdata+0x4):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:31:
> undefined reference to `open_dev_console'
> init.o(.sdata+0x8):/home/roger/Skrivbord/workdir/rtems-090316/c/src/../../testsuites/samples/hello/init.c:31:
> undefined reference to `rtems_filesystem_initialize'
> init.o(.sdata+0x40): undefined reference to
> `_RTEMS_tasks_Initialize_user_tasks_body'
> init.o(.rodata+0x0): In function `Init':
> undefined reference to `devFS_ops'
> /home/roger/Skrivbord/workdir/install/nios2-rtems/lib/mno-hw-mul/libc.a(lib_a-exit.o)(.text+0x28):
> In function `exit':
> /home/roger/Skrivbord/workdir/newlib-1.16.0/newlib/libc/stdlib/exit.c:65:
> undefined reference to `_exit'
> /home/roger/Skrivbord/workdir/install/nios2-rtems/lib/mno-hw-mul/libc.a(lib_a-wsetup.o)(.text+0x60):
> In function `__swsetup_r':
> /home/roger/Skrivbord/workdir/newlib-1.16.0/newlib/libc/stdio/wsetup.c:52:
> undefined reference to `_free_r'
> /home/roger/Skrivbord/workdir/install/nios2-rtems/lib/mno-hw-mul/libc.a(lib_a-__call_atexit.o)(.text+0x17c):
> In function `__call_exitprocs':
> /home/roger/Skrivbord/workdir/newlib-1.16.0/newlib/libc/stdlib/__call_atexit.c:89:
> undefined reference to `free'
> /home/roger/Skrivbord/workdir/install/nios2-rtems/lib/mno-hw-mul/libc.a(lib_a-findfp.o)(.text+0x8c):
> In function `__sfmoreglue':
> /home/roger/Skrivbord/workdir/newlib-1.16.0/newlib/libc/stdio/findfp.c:86:
> undefined reference to `_malloc_r'
> /home/roger/Skrivbord/workdir/install/nios2-rtems/lib/mno-hw-mul/libc.a(lib_a-fvwrite.o)(.text+0x188):
> In function `__sfvwrite_r':
> /home/roger/Skrivbord/workdir/newlib-1.16.0/newlib/libc/stdio/fvwrite.c:147:
> /home/roger/Skrivbord/workdir/install/nios2-rtems/lib/mno-hw-mul/libc.a(lib_a-fvwrite.o)(.text+0x3e0):/home/roger/Skrivbord/workdir/newlib-1.16.0/ne
> rtems-users mailing list
> rtems-users at rtems.com
