Nios2 problems when building tests
Morten Kristiansen
millibit+rtems at gmail.com
Tue Mar 24 08:30:12 UTC 2009
2009/3/20 Joel Sherrill <joel.sherrill at oarcorp.com>:
> My full NIOS patches are at home. Morten can help you
> get things going.
I should think so. I'll take a look at it this evening.
> The biggest issue you are facing is that the NIOS II binutils
> version Altera uses is TOO old for the feature used in cpukit/wrapup.
I fetched the relevant versions into Subversion and tried merging. It
wasn't straightforward, but as a quick solution I can create a patch
that allows it to read options from a file.
/MK
