i got error with runing ticker.exe from Quick Start
Daron Chabot
daron.chabot at gmail.com
Fri Mar 20 18:58:41 UTC 2009
Don't shoot the messenger... :-)
I don't think Ubuntu Intrepid (8.10) has this problem: Konstantin,
what version of ubuntu are you using ?
-- dc
On Fri, Mar 20, 2009 at 12:32 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Ralf Corsepius wrote:
>> Daron Chabot wrote:
>>> From this bug report (
>>> https://bugs.launchpad.net/ubuntu/+source/expat/+bug/218963 ), the fix
>>> seems to a symlink, as Joel has suggested:
>>> sudo ln -s /usr/lib/libexpat.so.1 /usr/lib/libexpat.so.0
>>> -- dc
>>> On Fri, Mar 20, 2009 at 11:04 AM, Joel Sherrill
>>>>> Joel Sherrill wrote:
>>>>>> Konstantin Volkov wrote:
>>>>>>> directory) i got the error sparc-rtems4.10-gdb:error while loading
>>>>>>> shared libraries: libexpat.so.0:
>>>>>>> cannot open shared object file: No such file or directory
>>>>> libexpat.so.0? Which distribution's rpm did you use to convert?
>>>>>>> why it can not find the file from ticker directory (there is
>>>>>>> ticket.exe in ticket directory
>>>>>>> why it answered what sparc-rtems4.10-gdb is not exist comand?
>>>>>> Since you used alien to convert the RPMs to Debian, you didn't
>>>>>> get the dependencies processed magically for you. I don't know
>>>>>> where that library comes from on Ubuntu.
>>>>> According to http://www.debian.org/distrib/packages, Debian ships
>>>>> libexpat.so.1 in its libexpat1.
>>>>> => The rpm based distro you used is likely incompatible to
>>>>> Debian/Ubuntu.
>>>>> => The package you would have to install is likely called libexpat1
>>>> I saw some Ubuntu traffic that other packages were having
>>>> trouble even building packages because of this library
>>>> and were recommending making a symlink as a fix.
>> Adding a symlink between ABI incompatible shared libs never is a fix -
>> It's a dirty hack.
> I agree 100%. But if it is their recommended workaround until
> a real fix is in place, it is their distribution.
>> Ralf
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
