Real Time Clock
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Mon May 11 11:45:10 UTC 2009
Ralf,
if I got Sebastians proposal right, he tends to convert the existing
functions proprietary to the RTC drivers into "Classic API" driver
calls, which can then be accessed through the I/O manager API. Among
others benefits, this will clean up that interface (no longer a
proprietary function set).
Accessing these drivers with the POSIX standard functions
(open/read/write/close) will then be possible without problem.
Please note: we are NOT talking about SW timers, we are taking about the
hardware device "Real-Time-Clock".
Do you have a pointer to a proper POSIX API to access such a device?
wkr,
Thomas.
Ralf Corsepius wrote:
> Joel Sherrill wrote:
>> Sebastian Huber wrote:
>>> Hi,
>>> I tried to write a shell command to read and set the real time clock (RTC).
>>> Unfortunately this is currently impossible to achieve within the cpukit.  One
>>> solution would be to extend the default RTC driver interface in
>>> cpukit/libcsupport/include/rtc.h:
>> I don't have a problem with adding some more standard interfaces
>> to the driver.  It should be possible to do it in a way that doesn't
>> impact any existing BSP or application.
> I am not excited to see yet another proprietary method being proposed
> related to timers.
> Instead, we should implement POSIX conformant calls with a appropriate
> syscalls underneath.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.org
Embedded Brains GmbH
Thomas Doerfler        Obere Lagerstrasse 30
D-82178 Puchheim       Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
