RTEMS Class example Timer : strange behaviour (to me)
pierre kestener
pierre.kestener at cea.fr
Thu May 14 12:39:15 UTC 2009
Hello,
I am running the timer class example on real hardware (Sparc/Leon2) with
printing on console.
Timer1 and 2 service routines are each set with a 2 seconds interval,
but I noticed that
after 2 fireouts, time between 2 LED_ON (or LED OFF) prints becomes 4
seconds.
To illustrate this, I put a rtems_time_of_day global variable named
"now" in the source code to use it to print time.
Here is the corresponding output :
*** LED BLINKER -- timer ***
LED ON 00:00:00
01/01/2009
LED OFF 00:00:01
01/01/2009
LED ON 00:00:02
01/01/2009
LED OFF 00:00:03
01/01/2009
LED ON 00:00:05
01/01/2009
LED OFF 00:00:07
01/01/2009
LED ON 00:00:09
01/01/2009
LED OFF 00:00:11
01/01/2009
LED ON 00:00:13
01/01/2009
LED OFF 00:00:15
01/01/2009
LED ON 00:00:17 01/01/2009
I also noticed that if I comment the line calling Timer2 service routine
Timer_Routine(Timer2, NULL);
in the Init task, then Timer1 is called twice and then it stops, no
print anymore.
LED ON 00:00:00
01/01/2009
LED ON 00:00:02
01/01/2009
Can someone help me and give some explanation of what seems strange to me ?
Thank you in advance.
Pierre Kestener.
