RTEMS Class example Timer : strange behaviour (to me)
pierre kestener pierre.kestener at cea.fr
Thu May 14 15:21:36 UTC 2009
More about timer example problem in Leon2 BSP :
I have tried different couples RTEMS toochain / RTEMS src :
- 4.9.0 from rtems.org
- RCC 1.1.1 from Gaisler (RTEMS scr 4.8)
- RCC 1.1.99.1 from Gaisler (downloaded in Feb 2009)
- RCC 1.1.99.3 from Gaisler (downloaded today)
the problem described below only appears with the latest Gaisler
toolchain/src 1.1.99.x
everything is fine when using the release toolchain/src 4.9.0 (from
rtems.org) or with the older Gaisler toolchain/src couple.
I haven't tried a more recent toolchain/src neither the CVS sources.
Pierre.
pierre kestener a écrit :
> Hello,
> I am running the timer class example on real hardware (Sparc/Leon2)
> with printing on console.
> Timer1 and 2 service routines are each set with a 2 seconds interval,
> but I noticed that
> after 2 fireouts, time between 2 LED_ON (or LED OFF)  prints becomes 4
> seconds.
> To illustrate this, I put a rtems_time_of_day  global variable named
> "now" in the source code to use it to print time.
> Here is the corresponding output :
> *** LED BLINKER -- timer ***
> LED ON  00:00:00
> 01/01/2009                                                  LED OFF
> 00:00:01   01/01/2009
> LED ON  00:00:02
> 01/01/2009                                                  LED OFF
> 00:00:03   01/01/2009
> LED ON  00:00:05
> 01/01/2009                                                  LED OFF
> 00:00:07   01/01/2009
> LED ON  00:00:09
> 01/01/2009                                                  LED OFF
> 00:00:11   01/01/2009
> LED ON  00:00:13
> 01/01/2009                                                  LED OFF
> 00:00:15   01/01/2009
> LED ON  00:00:17   01/01/2009
> I also noticed that if I comment the line calling Timer2 service routine
> Timer_Routine(Timer2, NULL);
> in the Init task, then Timer1 is called twice and then it stops, no
> print anymore.
> LED ON  00:00:00
> 01/01/2009                                                  LED ON
> 00:00:02   01/01/2009
> Can someone help me and give some explanation of what seems strange to
> me ?
> Thank you in advance.
> Pierre Kestener.
