Possible error in coremutex.c
Manuel Coutinho manuel.coutinho at edisoft.pt
Fri May 15 17:19:52 UTC 2009
Hi
Was seeing the differences between using and not using
__RTEMS_STRICT_ORDER_MUTEX__ and stumbled in what (I) find to be a possible
bug.
The coremutex.c has the following:
  if ( initial_lock == CORE_MUTEX_LOCKED ) {
    the_mutex->nest_count = 1;
    the_mutex->holder     = _Thread_Executing;
    the_mutex->holder_id  = _Thread_Executing->Object.id;
    if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
         _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) )
#ifdef __RTEMS_STRICT_ORDER_MUTEX__
       _Chain_Prepend_unprotected( &_Thread_Executing->lock_mutex,
                                   &the_mutex->queue.lock_queue );
       the_mutex->queue.priority_before =
_Thread_Executing->current_priority;
#endif
      _Thread_Executing->resource_count++;
  } else {
    the_mutex->nest_count = 0;
    the_mutex->holder     = NULL;
    the_mutex->holder_id  = 0;
In the older RTEMS versions, the
operation was inside the "if"
and now, if the strict order is defined, it is not.
My guess is that the 2 operations of the strict order mutex and the
resource_count++ operation must be inside the "if", because it makes sense
to do those operations with priority ceiling or inherence protocols.
Like:
         _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ){
<<<---- added bracket
#endif
      }  <<<---- added bracket
  } else {
That is, add the missing brackets.
Should the brackets be added?
Kind regards
Manuel Coutinho
URL: <http://lists.rtems.org/pipermail/users/attachments/20090515/65585f85/attachment.html>
