Possible error in coremutex.c
Joel Sherrill
joel.sherrill at OARcorp.com
Fri May 15 17:29:46 UTC 2009
Is this the diff you are proposing?
Index: cpukit/score/src/coremutex.c
RCS file: /usr1/CVS/rtems/cpukit/score/src/coremutex.c,v
retrieving revision 1.31
diff -u -r1.31 coremutex.c
--- cpukit/score/src/coremutex.c 29 Jul 2008 02:21:15 -0000 1.31
+++ cpukit/score/src/coremutex.c 15 May 2009 17:28:30 -0000
@@ -63,7 +63,7 @@
the_mutex->holder = _Thread_Executing;
the_mutex->holder_id = _Thread_Executing->Object.id;
if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
- _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) )
+ _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
#ifdef __RTEMS_STRICT_ORDER_MUTEX__
_Chain_Prepend_unprotected( &_Thread_Executing->lock_mutex,
@@ -72,6 +72,7 @@
#endif
_Thread_Executing->resource_count++;
} else {
the_mutex->nest_count = 0;
the_mutex->holder = NULL;
If so, my reading of the code agrees with you. I would like to hear
the opinion of others.
--joel
Manuel Coutinho wrote:
> Hi
> Was seeing the differences between using and not using
> __RTEMS_STRICT_ORDER_MUTEX__ and stumbled in what (I) find to be a
> possible bug.
> The coremutex.c has the following:
> if ( initial_lock == CORE_MUTEX_LOCKED ) {
> the_mutex->nest_count = 1;
> &the_mutex->queue.lock_queue );
> the_mutex->queue.priority_before =
> _Thread_Executing->current_priority;
> #endif
> } else {
> the_mutex->holder_id = 0;
> In the older RTEMS versions, the
> operation was inside the “if”
> and now, if the strict order is defined, it is not.
> My guess is that the 2 operations of the strict order mutex and the
> resource_count++ operation must be inside the “if”, because it makes
> sense to do those operations with priority ceiling or inherence protocols.
> Like:
> _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ){
> *<<<---- added bracket*
> #endif
> } *<<<---- added bracket*
> } else {
> That is, add the missing brackets.
> Should the brackets be added?
> Kind regards
> Manuel Coutinho
