RES: Embedded PC IDE Flash Questions
Wendell Pereira da Silva wendell.silva at compsisnet.com.br
Wed May 27 20:33:16 UTC 2009
Hello folks,
I have a similar issue with the e-box 4300.
(http://www.embeddedpc.net/eBox4300/tabid/190/Default.aspx)
Thanks in advance for some help.
COMPSIS... Computadores e Sistemas Ind. e Com. Ltda.
Aerospace Systems
Site: www.compsisnet.com.br
E-mail: wendell.silva at compsis.com.br
Phone: +55 12-2139-3966, ext. 977
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
Em nome de Joel Sherrill
Enviada em: quarta-feira, 27 de maio de 2009 16:22
Para: rtems-users at rtems.org
Assunto: Embedded PC IDE Flash Questions
Hi,
I have a Winsystems EBC-855 and am trying to
access the CompactFlash.  It is on
IDE1 and nothing is on IDE0 so I enabled the
secondary IDE/
http://sbc.winsystems.com/products/ebc-855.cfm
The IDE Flash is formatted for DOS and will boot
DOS.  I used the telnetd example with the DOS FS
support enabled.  The drive is showing up as
/dev/hdc but the system locks up when I
try to "fdisk /dev/hdc register" or
"fdisk /dev/hdc" to look at the partition table.
Any thoughts from someone who has done this
before?
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
