Real Time Clock
Joel Sherrill
joel.sherrill at OARcorp.com
Mon May 11 11:19:05 UTC 2009
Sebastian Huber wrote:
> Hi,
> I tried to write a shell command to read and set the real time clock (RTC).
> Unfortunately this is currently impossible to achieve within the cpukit. One
> solution would be to extend the default RTC driver interface in
> cpukit/libcsupport/include/rtc.h:
> #define RTC_DEVICE_NAME "/dev/rtc"
> #define RTC_DRIVER_TABLE_ENTRY \
> { rtc_initialize, NULL, NULL, rtc_read, rtc_write, NULL }
> rtems_device_driver rtc_initialize(
> rtems_device_major_number,
> rtems_device_minor_number,
> void *
> rtems_device_driver rtc_read(
> void *
> rtems_device_driver rtc_write(
> void *
> The read and write function would read or set the RTC with a rtems_time_of_day
> structure argument.
There are a few other IOCTL-type methods in the "RTC library
driver".
I don't have a problem with adding some more standard interfaces
to the driver. It should be possible to do it in a way that doesn't
impact any existing BSP or application.
Propose away.
> Have a nice day!
