Real Time Clock
Ralf Corsepius
ralf.corsepius at rtems.org
Mon May 11 11:37:12 UTC 2009
Joel Sherrill wrote:
> Sebastian Huber wrote:
>> Hi,
>> I tried to write a shell command to read and set the real time clock (RTC).
>> Unfortunately this is currently impossible to achieve within the cpukit. One
>> solution would be to extend the default RTC driver interface in
>> cpukit/libcsupport/include/rtc.h:
> I don't have a problem with adding some more standard interfaces
> to the driver. It should be possible to do it in a way that doesn't
> impact any existing BSP or application.
I am not excited to see yet another proprietary method being proposed
related to timers.
Instead, we should implement POSIX conformant calls with a appropriate
syscalls underneath.
Ralf
