warning flags was Re: rename issue
Sebastian Huber
Fri May 15 08:49:40 UTC 2009
Joel Sherrill wrote:
> I don't believe every warning flag is useful but some of the
> ones this BSP turned on are showing up real questionable
> type abuse.
> I am actually concerned about these:
> -mstructure-size-boundary=8
> -mapcs-frame
> which show up across a number of ARM BSPs. Either they
> match the default or potentially create incompatabilities
> with the libraries.
I have to admit that I also copied these flags from an existing BSP. They are
so common that you can think they are the standard for ARM BSPs. Does someone
know why are they present?
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
