RTEMS Traps and Interrupts
    Gedare Bloom
    gedare at gwu.edu
    Wed Nov 11 01:02:12 UTC 2009
On Tue, Nov 10, 2009 at 4:34 PM, Jamie Bowman
<jamie.bowman at steepestascent.com> wrote:
> All
> We have been developing a system based on the SPARC Leon 2 processor using
> RTEMS 4.8. We have successfully used the RTEMS call rtems_interrupt_catch to
> register interrupt handlers for a number of the 15 interrupt lines on the
> SPARC Leon 2 processor. On the SPARC Leon2 processor, interrupts are
> referred to as Asynchronous Traps with interrupts 1-15 being equivalent to
> traps 0x11–0x1F.
> What we would like to do now is to catch a number of the lower level
> processor Synchronous Traps, for example the trap associated with detecting
> an uncorrectable EDAC error when reading Data from SDRAM.
> Is there support within RTEMS to register such a trap handler?
I think it should work to install an interrupt handler as (trapnum +
256).  RTEMS will install the handler in such a way that the
ISR_Handler routine will fudge the return program counter to act as a
synchronous trap.
-Gedare
> Thank you for in advance for your assistance.
>             Jamie
> rtems-users mailing list
> rtems-users at rtems.org
