Rtems telnetd/shell question
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Tue Oct 27 21:59:43 UTC 2009
Well I should have read this before I posted.  I saw
a private question about this scenario and duplicated it.
This is the same thing I am seeing with telnetd.
In 4.9, you got the login prompt again but reconnection
worked.
--joel
Peter Dufault wrote:
> I'm trying to use the RTEMS shell with the RTEMS telnetd, and it hangs
> when I close down telnet.  If I close down the telnet session the
> shell task that was spawned by telnetd gets stuck forever in
> rtems_shell_line_editor() in the "empty line" logic at line 755 where
> it thinks it read a blank line, tries to prompt and doesn't see the
> error, and loops forever.
> I'm initializing it simply, similar to an example I saw:
> static void sh_wrap( char *dev, void *arg)
>      (void)rtems_shell_main_loop(arg);
> rtems_telnetd_config_table rtems_telnetd_config = {
>      sh_wrap,                /* Command */
>      NULL,                   /* Argument */
>      0,                      /* Priority */
>      RTEMS_MINIMUM_STACK_SIZE * 16, /* task stack size */
>      0,                      /* Login check */
>      0                       /* Keep stdio of the caller  */
> rtems_telnetd_initialize();
> I can't "exit" the telnet shell, either, it just restarts itself
> without closing the telnet connection.  I tried detecting the error
> when the shell printed the prompt and treating it as an EOF but that
> doesn't help, it must be trying to restart itself.
> Peter
> rtems-users mailing list
> rtems-users at rtems.org
