Want to use the powerpc e200z6 SPE APU
Peter Dufault
dufault at hda.com
Sun Oct 11 13:12:46 UTC 2009
On Oct 11, 2009, at 5:38 , Peter Dufault wrote:
> The default configuration of the compiler doesn't support them:
Actually it appears it does if you can figure out what arguments to
use, though the disassembler doesn't handle the instructions properly:
[dufault at finny motobank]$ cat foo.c
#include <spe.h>
void foo(void) {
volatile __ev64_s32__ v = __ev_create_sfix32_fs (0.5, -0.125);
[dufault at finny motobank]$ powerpc-rtems4.10-gcc -O -mcpu=8540 -mspe -c
foo.c
[dufault at finny motobank]$ powerpc-rtems4.10-objdump --disassemble foo.o
foo.o: file format elf32-powerpc
Disassembly of section .text:
00000000 <foo>:
0: 94 21 ff e8 stwu r1,-24(r1)
4: 3c 00 3f 00 lis r0,16128
8: 90 01 00 10 stw r0,16(r1)
c: 3c 00 be 00 lis r0,-16896
10: 90 01 00 14 stw r0,20(r1)
14: 10 01 13 01 .long 0x10011301
18: 10 00 02 97 .long 0x10000297
1c: 10 01 0b 21 vmhraddshs v0,v1,v1,v12
20: 38 21 00 18 addi r1,r1,24
24: 4e 80 00 20 blr
