Want to use the powerpc e200z6 SPE APU
Peter Dufault
dufault at hda.com
Sun Oct 11 17:31:29 UTC 2009
On Oct 11, 2009, at 9:12 , Peter Dufault wrote:
> though the disassembler doesn't handle the instructions properly:
After this I promise I won't follow-up on myself, especially on
weekends when everyone else is taking time off.
Obviously I'm overly busy right now.
You will find yourself in a twisty maze of options when working with
the SPU, to disassemble the SPE op-codes use -M e500:
[dufault at finny rtems]$ powerpc-rtems4.10-objdump --disassemble -M e500
foo.o
foo.o: file format elf32-powerpc
Disassembly of section .text:
00000000 <foo>:
0: 94 21 ff e8 stwu r1,-24(r1)
4: 3c 00 3f 00 lis r0,16128
8: 90 01 00 10 stw r0,16(r1)
c: 3c 00 be 00 lis r0,-16896
10: 90 01 00 14 stw r0,20(r1)
14: 10 01 13 01 evldd r0,16(r1)
18: 10 00 02 97 evfsctsf r0,r0
1c: 10 01 0b 21 evstdd r0,8(r1)
20: 38 21 00 18 addi r1,r1,24
24: 4e 80 00 20 blr
