Problems with floating-point support on ARM
Ralf Corsepius
ralf.corsepius at rtems.org
Mon Oct 19 15:07:00 UTC 2009
>> Ralf Corsepius wrote:
>>> Comments from other arm users? Will vfp work for your boards?
>> No comments from other ARM users in two weeks.
>> We should change the default floating-point model in GCC from FPA to VFP.
> It would be nice if the RTEMS 4.10 ARM GCC could use VFP as the default
> floating-point model. Is this the way to do it?
No, it isn't.
> Index: contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec
> RCS file:
> /usr1/CVS/rtems/contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec,v
> retrieving revision 1.55
> diff -u -r1.55 rtems-4.10-arm-rtems4.10-gcc.spec
> --- contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec 9 Oct
> 2009 04:20:08 -0000 1.55
> +++ contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec 19 Oct
> 2009 12:50:35 -0000
> @@ -244,6 +244,8 @@
> --with-gnu-as --with-gnu-ld --verbose \
> --with-newlib \
> --with-system-zlib \
> + --with-float=soft \
> + --with-fpu=vfp \
> --disable-nls --without-included-gettext \
> --disable-win32-registry \
> --enable-version-specific-runtime-libs \
> The ARM multi-lib configuration for GCC should be changed to:
> Index: gcc/config/arm/rtems-elf.h
> --- gcc/config/arm/rtems-elf.h (revision 152974)
> +++ gcc/config/arm/rtems-elf.h (working copy)
> @@ -31,14 +31,6 @@
> } while (0)
> - * The default in gcc now is soft-float, but gcc misses it to
> - * pass it to the assembler.
> -#undef SUBTARGET_EXTRA_ASM_SPEC
> -#define SUBTARGET_EXTRA_ASM_SPEC "\
> - %{!mhard-float: %{!msoft-float:-mfpu=softfpa}}"
> * The default includes --start-group and --end-group which conflicts
> * with how this used to be defined.
> Index: gcc/config/arm/t-rtems
> --- gcc/config/arm/t-rtems (revision 152974)
> +++ gcc/config/arm/t-rtems (working copy)
> @@ -5,6 +5,6 @@
> MULTILIB_EXCEPTIONS =
> MULTILIB_MATCHES = marm=mno-thumb
> -MULTILIB_OPTIONS += msoft-float/mhard-float
> +MULTILIB_OPTIONS += mfloat-abi=soft/mfloat-abi=softfp
> MULTILIB_DIRNAMES += soft fpu
> -MULTILIB_EXCEPTIONS += *mthumb/*mhard-float*
> +MULTILIB_EXCEPTIONS += *mthumb/*mfloat-abi=softfp*
> Have a nice day!
