Problems with floating-point support on ARM
Sebastian Huber
Tue Oct 20 08:13:29 UTC 2009
>>>> Comments from other arm users? Will vfp work for your boards?
>>> No comments from other ARM users in two weeks.
>>> We should change the default floating-point model in GCC from FPA to
>>> VFP.
>> It would be nice if the RTEMS 4.10 ARM GCC could use VFP as the default
>> floating-point model. Is this the way to do it?
> No, it isn't.
Ok, let me describe the problem. On little-endian ARM with soft-float the
floating-point support from Newlib and the tool chain is broken. You can see
this if you run the paranoia sample from the test suite or the following module
(test.c) compiled with "arm-rtems4.10-gcc -c -o test.o test.c":
#include <math.h>
#include <assert.h>
double volatile b = 1.0;
void test(void)
double a = scalbn(b, 2);
assert(a == 4.0);
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
