sparc gdb broken
Sun Sep 6 22:48:12 UTC 2009
Hi,
I am not sure what broke or how to debug it but
sparc-rtems4.10-gdb core dumps when you run something.
This is definitely why we need to test pre-releases. :)
$ rpm -qf /opt/rtems-4.10/bin/sparc-rtems4.10-gdb
rtems-4.10-sparc-rtems4.10-gdb-6.8.50.20090902-2.fc10.i386
(gdb) tar sim
Connected to the simulator.
(gdb) load
(gdb) r
Starting program:
/home/joel/rtems-4.10-work/build/gcc-testing/rtems/build-sparc-sis-rtems/sparc-rtems4.10/c/sis/testsuites/samples/ticker/ticker.exe
Segmentation fault
I will try a couple of the other simulators in gdb now
to see how they work.
Suggestions on debugging this welcomed.
--joel
