sparc gdb broken
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Sep 6 23:57:24 UTC 2009
psim works on powerpc-rtems4.10-gdb.
$ rpm -qf /opt/rtems-4.10/bin/powerpc-rtems4.10-gdb
rtems-4.10-powerpc-rtems4.10-gdb-6.8.50.20090902-2.fc10.i386
So this appears to be sis specific.
--joel
Joel Sherrill wrote:
> Hi,
> I am not sure what broke or how to debug it but
> sparc-rtems4.10-gdb core dumps when you run something.
> This is definitely why we need to test pre-releases. :)
> $ rpm -qf /opt/rtems-4.10/bin/sparc-rtems4.10-gdb
> rtems-4.10-sparc-rtems4.10-gdb-6.8.50.20090902-2.fc10.i386
> (gdb) tar sim
> Connected to the simulator.
> (gdb) load
> (gdb) r
> Starting program:
> /home/joel/rtems-4.10-work/build/gcc-testing/rtems/build-sparc-sis-rtems/sparc-rtems4.10/c/sis/testsuites/samples/ticker/ticker.exe
> Segmentation fault
> I will try a couple of the other simulators in gdb now
> to see how they work.
> Suggestions on debugging this welcomed.
> --joel
> rtems-users mailing list
> rtems-users at rtems.org
