m4 trouble
Konstantin Volkov
kv.russia at gmail.com
Mon Sep 21 15:55:49 UTC 2009
hello.
I got trouble with RTEMS tool instalation (windows
http://wiki.rtems.org/wiki/index.php/MinGW_Tools_for_Windows )
after all steps with wingw, msys, dtk, m4.
i added PATH
PATH=C:\msys\1.0\bin;%PATH%
and chack it.
But erroe happens in RTEMS tool instalation step:
please help. What is wrrong with PATH to m4?
life is good.
Konstantin
life is good.
Konstantin
URL: <http://lists.rtems.org/pipermail/users/attachments/20090921/25765af2/attachment.html>
cd /C/opt/rtems-4.9/Packages/Build
tar jxf /C/opt/rtems-4.9/Packages/Source/autoconf-2.62.tar.bz2
cd /C/opt/rtems-4.9/Packages/Build/autoconf-2.62
rm -rf mingw32-autoconf-2.62
mkdir mingw32-autoconf-2.62
cd /C/opt/rtems-4.9/Packages/Build/mingw32-autoconf-2.62
/C/opt/rtems-4.9/Packages/Build/autoconf-2.62/configure --prefix=/opt/rtems-4.9
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether /bin/sh -n is known to work... yes
checking for expr... /bin/expr
checking for GNU M4 that supports accurate traces...
Name: m4. troble.JPG
Type: image/jpeg
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090921/25765af2/attachment.jpe>
